Good stuff Anu - good way to use the DSP as a tool to get a desired result.
I have always been challenged with this question - never truly understood gain setting though I have seen it done multiple times. The idea of setting gain by ear never made sense (crank it till you hear distortion, and then back off a bit).
Those who have set my gains typically have used an O-Scope to determine ‘max-unclipped’ signal.
When I had the Helix - set everything at 0 - no EQ, levels at 0. Then use the Autosound 2000, disc 104 to get various tracks at various frequencies specific to individual drivers - at either -5db or -10db. Adjust gain on the amp until the O-Scope shows a good sine wave - not a flat top.
Then we would tune the system - adjusting levels, making significant cuts to EQ - which sometimes left me with very little headroom - near the top of the volume knob, and not enough output. We were using a lot of EQ cuts on those tunes.
A friend stated that in his research of how engineers set up sound systems for large venues (concerts, clubs), pre-EQ is done for each speaker near field, that is stored, then the speakers are placed in the venue and EQ for the room is done, then gain is verified / adjusted to max unclipped to compensate for the reduction of signal through EQ (this is from a faulty memory, but I think I have stated it correctly).
So we started to do it this way in the car - gains at zero, tune the car with levels / EQ applied, then use the disc 104 to set gains. More output was achieved......but the problem I have had and haven’t solved - what if you want to do another tune on another preset? In the concert / club analogy - the pre-EQ (near field of each speaker) doesn’t change - that is stored.....they zero the gains, put the speakers in another venue, EQ to that room, then maximize the gains on the amp.
But if I want to do another tune, my gains are set based on the tune I did before - which may or may not had a lot of level difference in the DSP and a lot EQ or very little compared to the new tune. This is my current situation.
Yours or Ryan’s method where Dirac is employed (for those of us with the MiniDSP DL) could be very effective for those have easy access to the gains on their amps and want one good tune (not a different tune per preset - comp, drive, fun, genre-specific). Zero everything, run Dirac (which will make correction for EQ / levels), then maximize the gain for that tune. And potentially through this straightforward method, one could do this for each ground-up tune that is done if desired. Unfortunately, my gains are a real pill to get to and to adjust. My installer recently adjusted mine - had a tune on the car, used disc 104, set everything according to the disc, and I get decent volume - but I’m always wondering if it is ‘optimal’.
