1 - 3 of 3 Posts
I want to flush mount the tweeters from the Massive Audio Ck6 component set. What keeps the tweeter from falling out? They will be going in carpeted kick panels.
Not sure what the ck6 tweeters look like off hand, but you can either pressure fit them or glue them from the back of the panel/ tweeter. Hot glue is convenient.
They have a little metal ring with teeth in it that you press on the back of the tweeter that secures it as a flush mount...but then the back plastic housing of the tweeter still has a tendency to fall off.
What I did was drill an exact fit for the flush mount (not sure if it was 2" or 2-1/8" or what) then taped the two pieces together with a liberal amount of electrical tape. The tape holds the two pieces together and also provides a "stop" for the flush mount.
1 - 3 of 3 Posts
