1 - 7 of 7 Posts
Any focal/mosconi dealer can order you a box. Im not sure if it will stay water resistant when you cut the squares in smaller pieces. I assume the side you cut wound no longer have the seal coating just the foam which would soak the water up. Why do you need to cut them? they can have a gap between each square.
Moderator
$216 per box, each box has 54 tiles in it. As Howard mentioned, any Focal, Mosconi, or Illusion Dealer in your area can order it for you.
1 - 7 of 7 Posts
