1 - 9 of 9 Posts
Hello Guys,
I have a set of Focal ES100K and the crossover is a pain to fit, I do have a DSP but only have one channel available for each set of mid/tweet.
Looking to add a filter or bass blocker to the tweeter.
They are crossed over OEM at: 12/12dB (3.5kHz)
FS is 1600hz
And these are the tweeter specs:
https://www.focal.com/sites/www.focal.fr/files/shared/catalog/document/tweeter_TKM-technical_sheet.pdf
What filter or bass blocker would be best to use so that I can wire them up together, the DSP would take care of not blowing the mid and I assume the filter would work in the tweet.
Similar to some coaxial systems that are not bi-ampable.
Thanks!
JC
How is it that you have a DSP, but only 2 channels available? What are the other channels being used for? Your proposed plan could work, but it's not a good plan. You'll be able to use a cap to set a HPF on the tweeter, and the DSP for either a HPF or LPF on the mid, but not both. It's not ideal. What are you doing with the DSP that only leaves you with this option?
Hello Joe,
This is an amp and dsp all in one from Helix that works as plug and play in BMWs all in one.
I cant free up any channels because they are all used.
The way I am thinking is I would only have to high pass the mids at around 200 hz then the tweeter filter will take care of the 3.5k and down.
I cant access more channels.
If the DSP was made for that car, why do you have extra speakers that don't have channels? Let us know more about what you did so we can help.
Because the OEM door speakers (mid and tweet) are wired inline with one channel on the amp and the tweeter has a capacitor in it.
I am trying to do the same only remove the crossover network from focal and just work with a filter/capacitor for the tweeter.
There really is no way to wire them active... I had other setups in other cars and active is much better. but in this one I can´t.
What you're trying to do, is a bad idea...
With that said; you've been rather vague on what you've got, and what you're trying to do...
As a fellow BMW owner, I know there isn't much room for a passive crossover. But it can (and should) be done...
Use the proper Focal crossover. Don't fuck around with a filter or bass blocker. You'll torch your tweeters.
I have passive crossovers in my rear doors, and if you've ever seen an Audiofrog crossover... they're MASSIVE. Almost twice the size of a Focal.
Get creative (I did).
Remove the guts of the crossover from the enclosure, and wrap it with something non-conductive. Electrical tape, if you have to.
This will dramatically reduce the size, and help you to fit it in the door.
Thanks for the response... finding the proper filter can you please elaborate why its a bad Idea? What am I missing here? I am just trying to mimic the OEM setup but with different drivers.
The mid is gonna try to play to 20k. That right there is gonna sound bad. And if you use just a capacitor for the tweeter it's only gonna drop off at 6db/octave. It will probably sound worse than the stock speakers that were in the car. They made it work because they had the knowledge of what both the speakers were doing. Maybe the stock mid had a natural rolloff that closely matched where the tweeter was crossed.
If you have to stay passive do what the previous post said. Make em fit. Can you run seperate wires to the mid and tweets. Put the crossover in the trunk? Or under the dash.
1 - 9 of 9 Posts
