1 - 3 of 3 Posts
i have a choice to make.............
i can get either the fountek neo3cd or the lcy108 ribbons for the same price-which one is better for higher spl applications?will be matched with seas ca18rnx08 mids.
DIYMA Founder
Tough to say. I'd probably go with the LCY108 since it has a wider vertical dispersion and slightly smoother response. It's also considerably more expensive, so it's somewhat more of a bargain.
thanks. that's the way i was leaning also.i found a 2496 close by for 320 bux,now i just need to order the power supply and i'm all set.what subs would you guys suggest i try that i can order from solen?at least 12"??
1 - 3 of 3 Posts
