I briefly searched and didn't find anything related to this. Let me start by first telling you system details:
06/07 Honda Accord with Factory Nav
2 MTX Subs & Amp in Prefab box, I think from Circuit City
Installed by same retailer. Install looks solid from what I have seen, wires are in flex tubing. Only issue I have seen is that the box isn't secured.
Problem: The subs cut out when a left turn is made. They will come back on eventually, or when a right turn is made (this is what was told to me). I haven't had a chance to look at the system myself yet and wanted to get your opinions before I did. On a previous occasion one of the wires had come loose from the speaker terminal, I think it could possibly have happened again, but as I said I haven't looked yet.
Thanks
Sounds like the remote wire for the amp was tapped into the wrong lead.
What do you think it was tapped into? Also, the problem has only been happening recently, leading me to believe if this was the issue it would have been present before now
