Had some water coming in via the air vents as well as them letting an obnoxious amount of road noise in so i decided to make a more "fart" designed vent. Basically i just took the originals out. lined the hole with butyl rope, stuck a piece of mlv to it and then cut slits into the mlv. Then put a line of gap filler expanding foam around it, then trimmed that. Expanding foam sticks to ****ing EVERYTHING so its just acting like secondary glue. Basically the MLV slits should let air go through when i close the door and there is a sudden pressure increase inside the car, but then return to their normal stiff sound blocking position. This is done on both sides. i just have pics of the one side with the enclosure. My phone takes trash pics. Sorry.
I have to say though. If you want a quiet car. Buy one because tracking down every tiny rattle in this car is a longggg process.
Note all the insulation, thinsulate and thin polyfill between the enclosure and the metal.
