I have another front stage set-up! These amps are new in the box, I will take pics when my daughter comes back with the camera. 4/CH Nakamichi PA1004
and a 2/CH Nakamichi PA2002. Both amp has internal xovers. here is a chance to go active for the price of one amp with the SQ that will not be beat at this price for two amps. $400 to your door. here are the specs, pics will come later. New in the box this won't last long as did my other two set-ups went fast. Its a hobby for me so I doing my share.
NAK PA2002
Specifications:
Power Output (4 Ohms): 100W x 2
Power Output (2 Ohms): 200W x 2
Power Output (1 Ohm): N/A
Bridged Power Output (8 Ohms): 200W x 1
Bridged Power Output (4 Ohms): 400W x 1
Bridged Power Output (2 Ohms): N/A
Two mono amplifiers bridged
Minimum Speaker Impedance: 2 Ohm
Power Bandwidth: 5Hz*30Hz
Frequency Response (1W / 4 Ohm): 5Hz-100Hz
Total Harmonic Distortion (at rated power, 4 Ohms): < 0.05%
Intermodulation Distortion: < 0.05%
Input Sensitivity: 190mV * 8V
Input Impedance: 22K
Signal to Noise Ratio (minimum sensitivity 22kHz bandwidth filter): 103dB
Stereo Separation (2kHz): 80dB
Damping Factor (20Hz, 4 Ohms): > 150
Crossovers:
High Pass 28-230Hz
Slope 12dB/octave
2nd Low Pass (channel 3+4) N/A
Slope N/A
Low Pass 33-200Hz
Slope 24dB/octave
Bass Boost at 42Hz: Yes
One-Band Parametric EQ: No
Phase Shift Control: Yes (L +R)
Auto Bridging: Yes
Manual Bridging: No
Line Output: Yes
Remote Bass Level Port: Yes
Protection:
Short Circuit Protection Yes
DC Protection Yes
Reverse Polarity Protection Yes
Thermal Protection Yes
Thermal Foldback Yes
Power Source: 12v DC negative ground
(10 * 15v allowable)
Current Consumption:
with music, 4 Ohms/Channel (avg.) < 20A
with sine wave, 4 Ohms/Channel < 35A
at idle < 1.5A
Dimensions: Width 11-1/4' 284.8mm Height 2-5/8' 66.4mm Length 11-13/16' 300mm
NAK PA1004
Specifications:
Nakamichi PA1004 (Brand New) 400 watt 4 Channel Amplifier
4/3/2 channel (50 W x 4; four ohms) amplifier
12dB/octave high and low pass variable frequency crossover
42Hz bass boost circuit
Input level control accommodating input levels from 150mV to 4 volts.
True line outputs; allow for the individual designation of the high and low pass filters as well as
a flat setting.
Low-profile design (less than 2.14')
Black matte finish with brushed silver accent
Remote bass level port (requires optional RBC-1)
Protection from short-circuits; thermal conditions etc.
Gold-plated speaker and power connectors
Time-delay turn-on/off eliminates 'thumps' completely
Nakamichi PA1004 - Nakamichi 4 Ch 400 Watt Amplifier
Nakamichi PA2002 - Nakamichi 2 Ch 400 Watt Amplifier
NAK PA2002
Specifications:
Crossovers:
High Pass 28-230Hz
Slope 12dB/octave
Slope N/A
Low Pass 33-200Hz
Slope 24dB/octave
Auto Bridging: Yes
Manual Bridging: No
Line Output: Yes
Protection:
DC Protection Yes
at idle < 1.5A
NAK PA1004
Specifications:
a flat setting.
