1 - 9 of 9 Posts
I have up for grabs two Arc Audio 2500XXK amps. Used, but still in very good shape. Used for less than one year. Original boxes/birth sheets. Small cosmetic blemish on one of amps on the far corner.
2 x 270W @ 4ohms
2 x 525W @ 2ohms
1 x 1050W @ 4 ohms bridged
THD: <0.05%
Freq. Response: 20Hz ∼ 20kHz
S/N Ratio: 105dB
Damping Factor: >2000 (1kHz)
Max. Current Draw: 135A
Fuse: 3 x 30A
Dimensions: 18" x 8" x 3.35" (45.7cm x 20.3cm x 8.5cm)
These are workhorse amps that provide massive amounts of clean power.
$300 shipped (in the US) for each amplifier. If you purchase both at the same time, I'll further knock a few bucks off the price.
You may contact me via PM or E-mail (best).
Thanks for looking.
--Mike
Would one of these be overkill for a front stage component set? Specifically a 2-way set of dynaudio's? Judging by the power specs, I don't want to fry the drivers...
Nope... set the gains accordingly and you'll be fine.
I'm running 280x2 rms to my dynaudio system 360.
1 - 9 of 9 Posts
