1 - 2 of 2 Posts
(2) Orion Colbolt CS500.5 5-Channel Amplifiers
Base Specs:
4-Ch x 50 Watts & 1-Ch x 150 Watts @ 4 Ohms
4-Ch x 70 Watts & 1-Ch x 300 Watts @ 2 Ohms
Signal Processing: Three continuously variable high pass (50Hz-1kHz) or low pass 30Hz-250Hz
Variable low pass crossover 30Hz to 2.5kHz
XBC12 Bass Boost
8 gauge power/ground
16 gauge speaker
High efficiency heatsink
PWM power supply
100% QC Tested
Fuse Size: (2)40 AMP ATC
Dimensions: 15.7" x 10.1" x 2"
Amp #1 - Solid 8.5+/10 with some fairly minor wear to the casing. Decal/logo is clean. Perfect working order, and includes both plugs.
Amp #2 - 7/10 with more extensive wear to both the casing and the logo/decal section. Also in perfect working order with both plugs.
Amp #1 - $175 obo - shipped/insured via UPS Ground.
Amp #2 - $140 obo - shipped/insured via UPS Ground.
Both together - $290 shipped/insured.
Included in prices above.
Amp #1:
Amp #2:
The purge continues! Solid, semi old school amps :)
wow, those are purdy... what is the REAL power output of these amps? are they about true to their ratings?
1 - 2 of 2 Posts
