1 - 15 of 15 Posts
Up for sale is a pair of Arc Audio amplifiers. FD4150 4 channel and FD1200.1 mono. They are in EXCELLENT condition. I've had them for about 1 year. I've never had one shut down on me or ever given me any problems whatsoever. They don't even have any significant scratches on them. The only real issue is that the mono amp has a slightly more faded color than the 4 channel. You can see it in the picture. It's only obvious under direct sunlight.
$380 for the mono and $280 for the 4 channel. I'll sell both together for $600. Prices do not include shipping.
Discussion Starter · #2 ·
Here are specs from the woofersetc site. Forgot to mention that both amps come with everything that came with them originally as you can see in the pictures. The end caps have never been used.
FD4150
Description:
# Microprocessor controlled
# Remote digital bass boost gain w/led status display
# Set and forget crossover switches on bottom plate
# Seperate front and rear high/low/full range select switch
# Seperate front and rear mono/stereo/full range select feature
# Heavy duty construction / Fan cooling
# Thermal, DC, offset, reverse voltage, over voltage, short circuit protection
Specifications:
# Output Power: 80x4 @4 ohms, 160x4 @2 ohms, & 320x2 @4 ohms bridged
# Transient distortion: < 0.005% @4ohms
# Frequency response: 20Hz - 20Khz
# S/N ratio (A wtg): > 105dB
# Bass boost: + 18dB @45Hz
# Input sensitivity: 250mV - 2.5V
# Crossover: 55Hz-5.5KHz variable 12dB
# Fuse: 30A x3
# Dimensions: 10 3/8"(W) X 21 7/8 "(L) X 2 3/8" (H)
FD1200.1
Description:
# 24dB lowpass crossover with 30Hz to 250Hz
# Master/Slave control
# Variable Sub Sonic filter
# Variable Bass Boost
# Fan cooling
# Concealed connections and controls
Specifications:
# Output Power: 510 x1 @4 ohms, 1,010x1 @2 ohms, & 1,100x1 @1 ohm mono
# Damping factor: 2100
# Frequency response: 20Hz - 250Hz
# S/N ratio (A wtg): >89dB
# Bass boost: +18dB @ 30 - 80Hz
# Crossover: 30 - 250Hz 12dB stereo
# Fuse: (3) 40 Amp fuses
# Dimensions: 10 3/8"(W) X 21 7/8"(L) X 2 3/8"(H)
Nice amps! I vouch for this seller...Great person :cool2:
nice clean amps you have there
Discussion Starter · #7 · (Edited)
I also have some image dynamics speakers for sale as well. I'll post a new thread with pictures.
I have some id8v3 subwoofers that i never got around to using. They are D2 and are new in original packaging. $95 each + shipping.
Also up for sale is a set of 6.5" 4 ohm CXS64 components. These are the original chameleons, not the V2's. They are used but in MINT condition. Includes nx30 tweeter, cx64 mid, and x4 passive network. $250 + shipping.
good guy. good amps. buy them now!! :
Discussion Starter · #11 ·
Thanks, Jim!
I would really like to keep these amps together if possible. It'd be sad to have to split them up.
I believe it goes:
se > fd > xxk > ks > kar
I couldn't find the thread that I saw that in, but I know it's on here somewhere.
Great amps and prices! That 1200 is quite beastly.
Best,
Jay
Its going to go SE > XXD > FD > XXK > KS > KAR I can't beleive I just leaked that.
Discussion Starter · #13 ·
You are incorrect. The new XXD amplifiers will be arc's new entry level series. KS will be replacing the FD's for the mid-level. FD and XXK are no longer being produced.
SE > KS > XXD
1 - 15 of 15 Posts
