First up is the scan D3004/6040-00 Beryllium. Used but in very good condition and 100% functional. These where bought from uncle Larry some time ago for a project, that never came to be.
See link for info:
Asking: $345 for these shipped in the U.S.
Next up the Bliesma T34B-4 Beryllium 34mm large format tweeters and pains me to sell these. As they are simple top 4 tweeter available today no matter the price range. Nothing produce for mobile audio comes close.
Features :
• 34mm beryllium dome with variable thickness for ultrasonic first breakup mode
• Extremely low moving mass for better transient response and higher efficiency
• Fully saturated neodymium motor with copper sleeve for low non linear and modulation distortion
• 3mm linear excursion and large vent channel for undistorted low frequency operation
• Narrow surround for less “soft dome” coloration
• Flush mounted surround and rear mounted magnet system for flat frequency response and wide off-axis response
• No ferrofluid for improved dynamics
• Underhung voice coil wound on titanium former
• Flexible and lightweight lead wires made in Denmark
• Thick aluminium powder coated flange
• Aluminium rear chamber with natural wool damping
• Gold plated wire terminals
• Extremely wide recommended frequency range 1.3kHz-40kHz
Asking $600 for these shipped in the U.S.
Quicks way to reach me is to text me directly:
404-683-8626
See link for info:
ScanSpeak Illuminator D3004/6020-00 Tweeter Textile Dome
ScanSpeak Illuminator D3004/6040-00 Tweeter Textile Dome. The Illuminator tweeters continue on with the heritage of the renowned Revelator series. The large-roll surround and textile dome diaphragm provide a flat frequency response to above 30KHz with outstanding off-axis dispersion.
www.madisoundspeakerstore.com
Manufacturer | BLIESMA |
Tweeter Type | Beryllium Dome Tweeter |
Cone / Dome Diameter | 34mm |
Impedance | 4 ohms |
Power Handling (RMS) | 80 W |
Frequency Response | 1300 – 40000 Hz |
Sensitivity | 97.5 dB |
404-683-8626
