FS: Carputer Parts (NEW) - CarTFT, Asus, BlackBox
938 Views 0 Replies 1 Participant Last post by  neverrain
Hey All,
I purchased a premium membership here so i can unload a few items I purchased for a Carputer project. Unfortunately, I ended up buying a new car that came with Nav, so I have no need for any of these items any longer.
All items are BRAND NEW and only opened far enough to test or display for pictures.
Also, I am aware that I am a very new member of this forum, so I would prefer to deal locally in person to avoid any assumption of a scam. If you are not local and would still like to purchase something, I can take whatever pics needed to satisfy your doubts. You may also refer to my trader rating on Zilvia (same username) here neverrain
I have 3 items for sale. It is generally easier for me to meet Sat-Mon because of work and I can meet within reason around 818 (SoCal) or Tues-Fri in Culver City, CA between 6pm and 8pm (I will be on a lunch break, so please take that into consideration).
1 - CarTFT Double Din 7" Touchscreen Monitor - CTF700-SHM
2 - Asus Mini-ITX Motherboard - AT3N7A-I Atom 330
3 - Black Box Mini-ITX Carputer Case
All items are brand new and never used/installed. See additional info for what is included within the boxes.
My asking price is as follows, please keep in mind that these are brand new and well below their retail prices. In terms of the screen, you are saving over $100.
1 - Screen $500
2 - Motherboard $100
3 - Case $80
I will ship any of these items at your expense. I can obtain an estimate for you, but I will need a day or two to do so (will likely need to do this on a weekend or Monday).
Pictures: -
CarTFT Monitor
Motherboard (Cocker Spaniel not included)
BlackBox (Apologies for lack of a decent case picture, it wasn't easy to get a good one. See the link above for a better case picture)
Parts included with each item:
Monitor -
  • Monitor
    Power Cable for the wall (The plug is European of some kind, you will need a US adapter if your wall requires one) - Used for bench testing the monitor
    Power cable for the car (what I used to show displays functionality)
    ~12" pigtail with inputs, Video, USB, etc
    Driver CD and booklets
MoBo -
  • 2 Sata Cables
    Rear I/O Shield
Case -
  • 2 End caps
    LCD power connector (for touch screen monitor power)
    4m/14' 18 AWG LCD power line set
    16 AWG 6 pin male and female wiring harness
    Optional 4 port USB panel
    RCA Jacks
    Hard drive and system power LED lights
    Reset switch
    Hardware mounting screws, wire ties, and quick connects
    Isolation bushings for the hard drive and motherboard
    Hardware mounting plate
    50mm high speed fan
    Flexible PCI Riser
Thanks for looking!
1 - 1 of 1 Posts
1 - 1 of 1 Posts
