I have a magazine review scan, and several pics. If you are interested, i will email them to you, but below are some specs:
Clarion Active Digital Control System, ADCS-1,
ProAudio AM/FM stereo, CD player w/CD changer controller DSP, Digital parametric EQ & crossover, DIN chassis w/detachable control panel.
Key features:
Tuner - *18 FM/6 AM
*Station category search tuning
*60 station memory, Call letter display
*Magi-Tune(tm)+FM
CD - *Full logic CD controls
*Programmable play 99 tracks
*Track music search FF/FB
*Audible FF/FB
*Last position memory
CD changer control - *Programmable play 99 tracks
*100 CD title memory display
*Direct disc select
*Multi-changer control capability
*Audible FF/FB
DSP - *5 preset sound balance memories
*5 sound field memories
*7 adjustable sound field parameters
EQ - *4 channel, 6 band digital parametric EQ
*Selectable center frequencies, 31 points, 1/3 octave adjustable Q
X-over - *14 channel digital crossover
*Selectable crossover points
*Selectable crossover slopes 12dB, 24dB, 36dB/octave
*Phase selectors
*Adjustable gain controls
*Independent adjustable time alignments
*5 preset memories
Audio - *Digital audio controls
*Digital fiber optic connections
*20 bit 4 channel D/A converters
*8 times oversampling
General - *Switchable illumination
*User infrared remote control
*Programming infrared remote control
*RS-232 port for parameter programming from DPAA computer
This year we are proud to introduce the Clarion Active Digital Control System (tm), the ADCS-1, as a total digital solution for balancing sound, time- aligning speakers, and creating sound fields that make a car audio system sound like the best home system and beyond. For the consumer, the Active Digital Control System (tm) consists of an X-DA1 4 channel D/A converter, and an X-DP1 central processor. (Adding three X-DA1's to the ADCS-1's central processor will expand the system to 14 channels) The latter unit acts as the brains of the entire system and is programmed to control signal processing, audio equalization, speaker time-alignment and various crossover functions, all within the digital environment. At the helm, the X-CD1 source unit has a built-in CD player with full-logic controls and is filled with features found only on our premium models. Yet this unit also functions as a full featured CD controller that can control up to four CD changers with an optional multi-changer switch box. The X-CD1's tuner section features our electronic quartz-locked PLL tuning with Magi-Tune(tm)+FM reception system. Tuned signals are converted to digital signals and are routed (as are CD signals) via a fiber-optic cable for processing in the ADCS-1's central processor. All audio controls are digital, and the system uses 20 bit D/A converters and 8 times oversampling digital filters to restore audio signals to original analog waveforms. To set-up and tune an installed Active Digital Control System(tm),
