1 - 6 of 6 Posts
old style kick butt coustic crossover from their Design Reference Series....
has balanced inputs, but you can use unbalanced as well...the front and rear inputs have a 0 or -10db attentuation switches.
you can run the front and rear outputs off of one input using the parallel input switch...
slopes of 6, 12, and 18db/octave are available on all 3 outputs...
level controls for left and right on each output....
stereo/mono switch on the sub out...as well as 0, 180 degree phase switch. bass boost from 25-45hz up to 12db gain on the sub output....
front outputs have a 20x mulitplier on the crossover section: front: 40-400hz, or 800-8000hz
rear (bandpass): highpass: 40-400hz or 400-4000hz
lowpass: 125-1250 hz, or 2500-25,000hz
lowpass output: 25-200hz...
case isn't in the best shape....but she worked perfectly when i hooked her up....bought it for $125 shipped....would like that or best offer since i only hooked it up for a few minutes....
http://www.coustic.com/classic/PDFs/DX-28.pdf
going to stick with my coustic xm5e and get an EQX to go along with it :)
Discussion Starter · #2 ·
if anybody wants pics....let me know....got the batteries juiced up for the camera today :)
You bumped an almost 4 year old ad, from a guy who hasn't posted here in almost 3 years?
1 - 6 of 6 Posts
