1 - 12 of 12 Posts
Eclispe XA1200 Sub amp. Bought new about a year and half ago. 350w @ 4 ohms, or 500w @ 2 ohms.
Used - 8.5/10 Condition. Looks good, just lost two of the screws that hold on the aluminum decorative pieces. I have one screw in per side in the pic, tha works fine.
$120 Shipped - Good prices for 500 W @ 2 ohms.
I had this amp installed for about a year, served me very well. I ran a SI mag V4 and Arc 12 with it, always had plenty of power with it at low gains.
Im just getting rid of it because Im in the process of changing it up and could use the $.
XA Series Class D Monoblock Car Amplifier with ICE Technology
• RMS Power Rating:
• 4 ohms: 350 watts x 1 chan.
• 2 ohms: 500 watts x 1 chan.
• Max power output: 600 watts
• MOSFET switching power supply
• ICEpower class D design
• Wired remote bass level control included
• LED power indicators
• Bass Boost (0-8 dB at 50 Hz)
• Bass boost frequency selection (32-64 Hz)
• Mono channel operation
• Protection temperature (90 C)
• Heavy duty aluminum alloy heatsink
• RCA level inputs
• Screw terminals
• Variable low-pass filter (40-200 Hz, Linkwitz Riley 18 dB/octave)
• Subsonic Filter (18 dB at 20 Hz)
• CEA-2006 compliant amplifier
• Frequency response: 20-20,000 Hz
• Input sensitivity: 1.2V-8V
• damping Factor: 90
• Dimensions: 10-1/4"L x 10-1/8"W x 2-3/8"H
• 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
good deal here
1 - 12 of 12 Posts
