1 - 8 of 8 Posts
------------------------ Drivers --------------------------------
1. Pair of JL Audio 10" W6v2 Subwoofers
2. Focal 165 KRX2 2-Way component kit
3. Focal 165KRC 2-Way Co-Axial Speakers
4. Pioneer TS-A1674R 6.5" 3-Way Speakers
----------------------- Amplifiers ----------------------------------
4. JL Audio Slash v2 1000w Monoblock Amplifier (1000/1v2) - SOLD
5. JL Audio Slash v2 450w 4-Channel Amplifier (450/4v2)
6. JL Audio Slash v2 300w 4-Channel Amplifier (300/4v2) - SOLD
----------------------- Others --------------------------------------
7. JBL MS-8 Digital Signal Processor
8. Pioneer F90BT double-din head unit w/ installation kit for certain Ford models.
9. Pioneer DEH-6400BT single-din head unit - New in Box - $100
10. Dynamat Xtreme Bulk Pack - SOLD
11. JL Audio 00 Gauge Amp Wiring Kit
12. Various Streetwires RCA Cables (12-15ft 2-Channel Shielded, x2-3 short splitters, x4 3-5ft 2-Channel unShielded)
To keep this post streamlined, I'm going to rely on the viewer to Google any specs of the equipment. If there is a problem in doing this, please request them below.
1. Pair of JL Audio 10" W6v2 Subwoofers - USED
- Cosmetic: Good​
- Working Order: Perfect​
- Included in Sale/Packaging: Sale includes Two JL Audio 10w6v2 10" subwoofers. I need to report back on if I have the jumper wires to change the voice coil impedance. I don't believe I have the original boxes for these items, and if so no manuals (are available on JL's website). If picked up locally, I give you the sealed enclosure they've been in for free.​
2. Focal 165 KRX2 2-Way component kit - USED
- Cosmetic: Good/Fair; Speakers have some corrosion in the plating on the back plate that doesn't affect operation. Tweeter faces could be polished. Crossovers are brand new, as the system was ran active.​
- Working Order: Mids and crossovers are in fine working order. Both tweeters will be included although only one is in working order, the other has a shorted voice coil (I mistakenly wired the tweeter to the channel for one of the mids :blush:).​
- Included in Sale/Packaging: Sale includes Two 6-3/4" Woofers, Two inverted dome tweeters (with attached 22" length of speaker wire), 2 Tweeter flush mount cups (installed), 2 Tweeter angle mount adapters, 2 Crossover networks, 2 Woofer grilles, 2 Woofer grille mounting rings, 2 Black tweeter grilles (installed), 2 Silver tweeter grilles, 2 Woofer mounting gaskets, 16 Speed clips, Twelve 5/8" Self-tapping screws (T10 Torx head), Twenty 1" Self-tapping screws (T20 Torx head), Owner's manual (English/ French). Comes in undamaged original box.​
3. Focal 165KRC 2-Way Co-Axial Speakers - USED
- Cosmetic: Good; Crossovers are used and may have a cracked mounting hole tab or two. Each still has other tabs as well as an adhesive on the backside. Does not affect performance.​
- Working Order: Fine working order.​
- Included in Sale/Packaging: Two 6-3/4" Coaxial speakers, 2 Crossover networks (w/ speaker leads), 2 Grilles, 2 Grille mounting rings, 2 Mounting gaskets, 8 Speed clips, 2 Machine screws, Four 5/8" Self-tapping screws, Twelve 1" Self-tapping screws, Owner's manual (English/ French). Comes in undamaged original box.​
4. Pioneer TS-A1674R 6.5" 3-Way Speakers - BRAND NEW IN BOX
- Cosmetic: Perfect. Still in original plastic wrap.​
- Working Order: Brand new.​
- Included in Sale/Packaging: Two 3-way 6.5/6.75" Speakers, 2 Grilles, Two 12" lengths of speaker wire (each has quick-slides on one end and bare wire on the other), 8 Self-tapping screws, 8 Speed clips, Warranty sheet, Template and specifications on box. Comes in original box, box has a tear in it (no damage to parts).​
Only included to show mating components of other items.
5. JL Audio Slash v2 450w 4-Channel Amplifier (450/4v2) - USED
- Cosmetic: Scuff on top surface from rubbing on mounting rack.​
- Working Order: Fine.​
- Included in Sale/Packaging: Included in sale is One JL Audio Slash v2 450/4 amplifier. Comes in undamaged original box. Need to confirm manual but available on JL's website.​
7. JBL MS-8 Digital Signal Processor - USED
- Cosmetic: Unit is nearly perfect cosmetically; still has the plastic film on glass face. Display has some scratching on face.​
- Included in Sale/Packaging: Included in sale is One JBL MS-8 Digital System Processor, 5-line LCD Display, Display Mounting Bracket, LCD Display Cable, Wireless Remote Control, Flush and Surface Mount hardware for wireless remote, Bi-aural Microphone Headset, Speaker input/ouput harnesses, Dual-Sided Self-Adhesive Pads, Alcohol Prep Pads, (x2) Setup and Owner's Manual CD's, and Quick Start Guide in 16 languages. Comes in undamaged original box.​
8. Pioneer F90BT double-din head unit w/ installation kit for certain Ford models. - USED
- Cosmetic: Unit has a decent amount of wear. No significant scratches on screen or trim. Volume knob pait has worn off. Wiring harnesses have been hacked for video playback while vehicle is in motion ("hardwired hack").​
- Included in Sale/Packaging: Included in sale from original kit is One Pioneer F90BT unit, both Pioneer wiring harnesses, GPS antenna, GPS antenna adhesive mounting square, microphone and cable, iPod cable (non-Lightning), and manuals. I will include a vehicle specific wiring harness (Guaranteed to work for a 2002 Ford Escape - Crutchfield claims it fits select 1998-2003 Ford, Lincoln, Mercury, and Nissan vehicles. Look up Item# 120705517 on Crutchfield's website and see if it fits yours by entering your vehicle.), and a double din mounting bracket (I had to trim back some of the plastic around the stock mounting hole to fit this in the Escape). Comes in undamaged original box.​
9. Pioneer DEH-6400BT single-din head unit - BRAND NEW IN BOX
- Included in Sale/Packaging: AM/FM CD receiver (with 10-amp ATM mini fuse inserted into chassis), Face (attached), Sleeve (installed), Trim ring (installed), Wiring harness, Wireless remote control (QXE1044), CR2025, Lithium battery (installed), External microphone (with attached 13' cable terminated by a right-angle male 2.5mm connector), Visor-bracket, Two-sided tape, 5 Self-adhesive cable clamps, 2 Extraction keys, 4 Pan head ISO-mount screws (M5 x 8mm), 4 Flat-head ISO-mount screws (M5 x 9mm), Face fixing screw, and Owner's Manual (Eng/Fre/Spa). Comes in undamaged original box. Will include the vehicle specific wiring harness in this sale if it applies to you.​
11. JL Audio 00 Gauge Amp Wiring Kit - USED
Will include a 15ft+ length of 00 gauge OFC wire (blue insulation), an inline fuse holder, a smaller 2-3ft piece of 00 gauge wire (blue insulation), various pieces of 4 gauge OFC wire (blue insulation), a grounding bolt, and a few pieces of 4 gauge OFC wire (grey/black insulation) (all JL). May include a x2 00 gauge to x4 4 gauge distribution block (Stinger?) and/or a x1 00 gauge to x2 4 gauge distribution block (JL Audio).​
Will confirm specifics later. Fine working order. No original packaging.​
---------------- Speakers / Subwoofers ------------------------
1. Pair of JL Audio 10" W6v2 Subwoofers - $250 each, $450 for the pair
2. Focal 165 KRX2 2-Way component kit - $600
3. Focal 165KRC 2-Way Co-Axial Speakers - $400
4. Pioneer TS-A1674R 6.5" 3-Way Speakers - $60
4. JL Audio Slash v2 1000w Monoblock Amplifier (1000/1v2) - $350 (SOLD!)
5. JL Audio Slash v2 450w 4-Channel Amplifier (450/4v2) - $350
6. JL Audio Slash v2 300w 4-Channel Amplifier (300/4v2) - $200 (SOLD!)
7. JBL MS-8 Digital Signal Processor - $300
8. Pioneer F90BT double-din head unit - $150
9. Pioneer DEH-6400BT single-din head unit - $100
10. Dynamat Xtreme Bulk Pack - $125 (SOLD!)
11. JL Audio 00 Gauge Amp Wiring Kit - $Make Me an Offer
12. Various Streetwires RCA Cables (12-15ft 2-Channel Shielded, x2-3 short splitters, x4 3-5ft 2-Channel unShielded) - $Make Me an Offer
All items can be picked up locally in northern Rhode Island. I will take ~5% off the asking price for any item picked up locally with cash. For other items, buyer will pay shipping. If an exact quote is desired, please request.
I am selling this equipment because the car it was installed in died and I don't have the heart to tear down my new car. I regret having to do this but feel that these items need a new home. Please help me make this quick and painless.
I am willing to accept offers but please be reasonable.
To the top!
Gubeelee, thanks for your support. Prices are set to sell...I'm not trying to make a fortune here, just want to see my beloved system go to better use.
Item availability is current to this moment.
I'm now asking $329 on the MS-8, as I believe I quoted this item too low. I have been in communication with a local buyer for an even higher price, if they fall through glockcoma is first in line if he'll meet the new asking price.
Other prices reduced as follows (+ shipping costs):
1. Pair of JL Audio 10" W6v2 Subwoofers - $219 each, $398 for the pair
2. Focal 165 KRX2 2-Way component kit - $489
3. Focal 165KRC 2-Way Co-Axial Speakers - $349
4. Pioneer TS-A1674R 6.5" 3-Way Speakers - $49
4. JL Audio Slash v2 1000w Monoblock Amplifier (1000/1v2) - $SOLD
5. JL Audio Slash v2 450w 4-Channel Amplifier (450/4v2) - $339
6. JL Audio Slash v2 300w 4-Channel Amplifier (300/4v2) - $SOLD
7. JBL MS-8 Digital Signal Processor - $329
8. Pioneer F90BT double-din head unit - $119
9. Pioneer DEH-6400BT single-din head unit - $89
10. Dynamat Xtreme Bulk Pack - $SOLD
As always, I'll negotiate on prices for local cash pickup.
Those are the exact speakers I'm looking for, front and rear for my M5. Sadly no money to buy right now. Not until my stuff sells.
How'd you have the 450/4 running the front speakers active?
GLWS And bump for what looks like was a great setup.
Shoot me an idea of what you want for all the cables and wire kit...cuz I have no idea, and don't want to insult you.
Thanks
1 - 8 of 8 Posts
