1 - 11 of 11 Posts
Xtant a4004
4x50W @4ohm
2x200W @4ohm
* Fully Regulated PWM Power Supply
* N-Channel MOSFET Design
* Defeatable Balanced Input
* Continuously Variable 24dB/Oct Low Pass Crossover 40-120Hz (Found only in rear channels)
* Continuously Variable 12dB/Oct High Pass Filter 40-120hz (Found in front & rear channels)
* Bass Boost at 45 Hz 0-12dB (Found only in rear channels)
* Active Resonance Control (ARC) (Found only in front channels)
* 4 Full Range RCA Outputs
I've had a (2) 404m's and (2) a4004's. The a4004's are better. This has also been shown on some crazy Russian site.
Corner is bent somehow. Otherwise, 100% functional.
Looking for $125 OR a 2 channel from:
-PPI
-Phoenix Gold
-Orion
You can reach me via PM or post in here.
Thanks.
Now on ebay. Typical. Either I get no bites here or I end up selling something for way less then it's worth. Such is life :D
1 - 11 of 11 Posts
