1 - 5 of 5 Posts
Guys I'm upgrading my subwoofers and I need more RMS power to move them.
This amp have been used for less than 1 hour, just to test how it moved my Rockford T110D4 wich moved great, but I want to add one more rockford sub and I need more watts. My setup was bridged 220wRMS x 2 powering the DVC sub, 220wRMS to each coil. NO SCRATCHES still smells new, comes with box and everything it came with. This amps are underrated. $200 Shipped
Details:
4-channel car amplifier
70 watts RMS x 4 at 4 ohms (110 watts RMS x 4 at 2 ohms) at 14.4 volts
45 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms) at 12.5 volts
220 watts RMS x 2 at 14.4 volts (150 watts RMS x 2 at 12.5 volts) at 4 ohms
differential-balanced inputs
Advanced Rollback Protection System
variable high- and low-pass filter (50-200 Hz, 12 dB/octave)
switchable bass boost (0, 6 dB at 48 Hz)
optional wired remote bass boost
Absolute Symmetry™ Class-AB amplifier design
MOSFET power and output stages
preamp-level inputs
speaker-level input with optional converter
preamp outputs
4-gauge power and ground leads and a 40-amp fuse recommended
14-3/16"W x 2-1/2"H x 9-5/16"D
Signal to Noise Ratio 104 dB
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=a4300&i=136A4300
1 - 5 of 5 Posts
