Looks a little rough but works like a champ. Awesome amps, A/B on the front channels, class D on sub. $200 shipped to the Lower 48 and Canada. No trades.
Reviews:
I've had this amp about a year now and I've used it to run all kinds of systems from 2 8in kickers to a pair of jlw3s. I've ran it at 2ohms on all 3 channels for hours and its never even gotten hot. if you want crystal clear highs and deafening bass with one amp then this is the only way to go.
Powers a 12 Type r & two high powered tweets(125rms) . Does a solid job, but I'm sure the type r wants a lil more juice. Birthsheet says 783 rms total
  • ZX Series 3-Channel Class AB with Class D Subwoofer Channel Car Amplifier
  • Channel 1 + 2 RMS Power Rating:
    • 4 ohms: 70 watts x 2 chan.
    • 2 ohms: 85 watts x 2 chan.
  • Subwoofer Channel RMS Power Rating:
    • 4 ohms: 210 watts x 1 chan.
    • 2 ohms: 420 watts x 1 chan.
  • Total RMS power output at 2 ohms: 590 watts
  • Max power output: 1100 watts approx.
  • MOSFET power supply
  • Wired remote bass level control included
  • LED power and protection indicators
  • Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
  • Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
  • Eliminates unwanted noise in a system
  • Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
  • Bridgeable operation
  • Speaker-level inputs compatible (switchable) through RCA connection, Kicker 09ZISL required and sold separately
  • Automatic turn on modes: remote, DC offset, or signal sense
  • Thermal, voltage, and short circuit protection circuitry
  • Variable high-pass filter (50-200 Hz, 12 dB/octave)
  • Subsonic Filter (24 dB at 25 Hz)
  • CEA-2006 compliant amplifier
  • Frequency response: 20-20000 Hz
  • Dimensions: 16-3/4"L x 9-5/8"W x 2-1/8"H
