1 - 14 of 14 Posts
Linear power 4253IQ
ACCUMATCH SAM 500's
ORION XOVERS
EARTHQUAKE (PPI) NOISEGATE SOLD !!
ALL USED EXCEPT FOR THE ORIONS
LINEAR POWER 140.00
ACCUMATCH SAM'S 125.00
ALL THE ORIONS 75.00
EARTHQUAKE 30.00
I WILL TAKE CARE OF IT !
No overseas at all, if shipping to canada you pay for shipping..
First up is a nice mid and tweet amp that needs no introduction the 4253IQ, i used this one on an install some time ago and used it only for tweeter duty. Pretty nice shape, few scratches and scuffs here and there. Works and sounds great. I had the speaker terminals, but i can't find them, Ray at tips has them. Wire will slip right over the spades easy. Link for specs below.
Linear Power Specifications: 4253IQ
Linear Power, Inc. - Linear Power Accessories
Up next are sweet little Gems i run with an orion red install once. These divide the speaker load by 2 4 or 8. These are awsome install pieces. Do some research on these please. These are the 500 watt models.
Next are the orion passive Xovers, if some may want to add a mid or tweeter to an install to keep it simple, or use them on a bench setup, these are new never used. (CSX-DT8 tweeter module 18db octave) (CSX-MR4 midrange module 4ohm 18db octave) Please do research for more info.
Last is the Earthquake NG2000 noisegate made by ppi, you all know what a noisegate does !! nice but not perfect, collector piece, or use it..
I tried to explain things fairly simple, i may have forgotten or gotten a couple things wrong, and if so, please chine in, i don't know it all. I'm only human !!
Paypall prefered it's simple and fast.
You have been spending too much time in the basement! Nice LP!
Sent from my DROIDX using Tapatalk
Banned
From what I read in the manual and on the box, there are 3 different units the SAM-500, the SAM-100, and the SAM-1200. The SAM-500 is optimized for 500 watts - 80 Hz - 3,000 Khz and the SAM-100 is optimized for 100 watts - 600 Hz - 20 Khz. There are no specifications for the SAM-1200 but it "...can be used for full range or band limited systems."
The accumatch has 6 wires 2 for inputs white(-) & brown(+), 1 common output white(-), and 3 outputs red (divides load by 2), orange (divides by 4), and blue (divides by 8).
1 - 14 of 14 Posts
