Mosconi zero 3 (few hours of testing) like new!
2 Channel AB class, Full MOSFET Amplifier
Power Rating: 270 Watt per channel @ 4 Ohm < 1% THD+N
1 Ohm stable
Damping Factor exceeds 3000
101dB S/N ratio (A weighted)
Very low THD and IMD
Regulated power supply
High/Low level selector ( HL / LL)
Auto REMOTE function
Cross Over with separate High Pass and Low Pass filter, Band Pass allowed
Slot for G_cards (G_HOC, G_HP, G_LP, G_FSA)
Remote Volume Control RTC_MOS (optional)
Side panels in soft touch finishing with red LED lighting
Dedicated to 150th Anniversary of the unification of Italy
Available in Silver-Satin Finish
Sn Ratio: > 71 dBA (ref: 1 Watt into 4 Ohm)
Specifications:
Power Handling:
520 Watt per channel @ 2 Ohm
1040 Watt BTL mode @ 4 Ohm
1850 Watt BTL mode @ 2 Ohm*
Input sensitivity (Power rating ref): 0.2 V ÷ 5 V (LL) / 0.8 ÷ 20 V (HL)
Xover functions (BAND Pass allowed):
HIGH Pass & LOW Pass
(20 ÷ 175 Hz) & (50 ÷ 300 Hz)
12 dB/oct – 0.7 (Stereo & Mono)
Dimensions: 450 x 250 x 50 mm
1 Ohm stable
Specifications:
Power Handling:
