1 - 1 of 1 Posts
MTX
**Thunder 282 2 Channel Amplifier
Input
Hi Level w/ Smart Engage
Low Level Input
Crossover(s)
Hi / Low @ 85Hz - Fixed, Defeatable
RCA Output
Full Range Only
RMS Power 12.5 VDC
2 Ohm Load 90 w x 2
4 Ohm Load 45 w x 2
Bridged 4 Ohm Load 180 w
Dynamic Power 14.4 VDC
2 Ohm Load 140 w x 2
4 Ohm Load 70 w x 2
Bridged 4 Ohm Load 280 w
Dimensions (with ISO Feet)
9.4" x 9.75" x 2.1"
23.9cm x 24.8cm x 5.3cm
**Thunder 421D Mono Amplifier
Low Level Input
Crossover(s)
Low Pass @ 40Hz-200Hz - Variable
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
RMS Power 12.5 VDC
2 Ohm Load 300 w x 1
4 Ohm Load 150 w x 1
2 Ohm Load 420 w x 1
4 Ohm Load 210 w x 1
9.4" x 9.75" x 2.1"
INFINITY
**Reference 1040W Subwoofer
10" 4-ohm component subwoofer
innovative basket design
polypropylene woofer cone with large-roll rubber surround
frequency response: 25-400 Hz
power range: 60-250 watts RMS (1,000 watts peak power)
sensitivity: 91 dB
progressive spider design
top-mount depth: 4-1/2"
sealed box volume: .75 cu. ft.
ported box volume: 1.75 cu. ft.
All are used. I have pics of the 421D and 1 1040W woofer. I can snap a pic of the thunder 282 and other 1040W if necessary. I bought them all around the same time. The amps never had a problem, nor did the subs. I had them in a reg cab Ranger and have sold it and now I need to get rid of my gear.
Thunder 282: 60 shipped
Thunder 421D: 80 shipped
Infinity 1040W: 50 each + half shipping
I'll cover shipping on the amps, and half for the subs. I don't gouge on shipping.
Heatware: Dallus
ebay: dallusglockin
1 - 1 of 1 Posts
