Nakamichi CD-700II (JDM version - Japenese Domestic Market)
Excellent shape. Sounds really beautiful!
9/10 - Only issue is a VERY small amount of LCD bleed in the top right corner of display. See close up photos. A few light scratches on display plexiglass, usual for age).
10/10 - Functional
$575, includes shipping
No trades at this time.
Included to lower 48. Alaska, Hawaii, Canada, UK, extra.
Pictures later tonight.
Haven't seen one of these legendary units in a while, since I sold my CD-700.
Been testing this one on the bench for a few weeks also and no issues at all. No skipping, no load or eject problems. Been rock solid. Let me know if you have any questions. Comes with the CD transport lock plate!
Only selling, because I have a limited production Nakamichi CD-700 Millennium (Special Shop Version of the CD-700).
Retail = $1700 - $2000(?) (back in year 2004)
Some highlights:
*4-gang, analog volume control, which is supposed to substantially improve channel separation and sound quality (so buttery smooth!)
* 5 mm-thick solid aluminum faceplate (no scratches)
* Upgraded (as compared to the original CD-700) and stronger magnetic disc clamping system. This stronger magnetic force and refined disc chucking assembly is responsible for greater stability and a substantial reduction in jitter.
Inputs/Outputs:
Digital Input - Coax (Works awesome with my Fiio X3/X5!)
Digital Output - Coax
AUX In - Analog RCA
5V Front and Rear Pre-outs - Analog RCA
32, 44.1 or 48 kHz sampling frequency auto selected
Preamplifier Section:
Frequency Response: 15-30,000 Hz ± 1 dB (AUX to Pre-Out)
Total Harmonic Distortion: 0.001% (1 kHz)
AUX Input Level/Impedance: 1 V/10 kohms
CDC Input Level/Impedance: 1 V/10 kohms
Output Level: 5 V
Tone Controls: (CAN BE DEFEATED)
Bass:
± 12 dB @ 20 Hz
Midrange:
± 9 dB @ 1 kHz
Treble:
± 6 dB @ 20 kHz
CD Player Section:
Error Correction: CIRC Principle
Sampling Frequency: 44.1 kHz
D/A Converter Type: Hand-selected left and right channel 24-bit ladder-type D/A converter with 8-times oversampling digital filter
Frequency Response: 20 - 20,000 Hz ±1 dB
Signal-to-Noise Ratio: Better than 105 dB
Dynamic Range: Better than 100 dB
NOTE: The JDM version does not have a sub pre-out (don't know if the US/World version CD-700II did or not...).
ALSO NOTE: Not that it should matter, but the JDM CD-700II was Made in China. The US/World versions of the CD-700II were Made in Malaysia, NOT Japan (like the CD-700).
This version has a Japanese tuner (76-90 MHz). Needs an FM expander to get entire US FM range. Best ones here:
Electronic Developments Ltd - Radio Band Expanders for imported cars - New Zealand
fm BAND e x p a n d e r s
More Info and old CarSound Review (of the original CD-700):
CD-700II
http://www.nakamichi.com/pdf/Naka%20-%20CD700II%20FA.pdf
Nakamichi CD700
Nakamichi CD700 Charts
10/10 - Functional
Some highlights:
Inputs/Outputs:
AUX In - Analog RCA
Output Level: 5 V
Bass:
± 12 dB @ 20 Hz
Midrange:
± 9 dB @ 1 kHz
Treble:
± 6 dB @ 20 kHz
CD Player Section:
CD-700II
Nakamichi CD700
