Brand new Eclipse CD8053 head unit for sale. It comes with everything from the original sale minus the harness that can be bought on Amazon or ebay for $5. The cage is the only item that has seen some use. One of the best sounding head units I've had the chance to use. You are able to run 3-way active with this unit in pro-mode. It also provides time alignment and parametric eq tuning capabilities.
$270 Shipped
Eclipse CD8053 Manual
Eclipse car audio CD8053 key features
Balanced outputs
High voltage 16 Volt / 8 Volt and low impedance outputs
All digital circuitry
STAR DSP (newly designed Digital Signal Processor)
24-bit advanced multi-bit Digital-to-Analog Converter
CD-R/CD-RW compatibility
MP3 playback using optional ECLIPSE Commander Advance
Full dot VF display
Power tilting front panel
Digital input
Auxiliary input
$270 Shipped
Balanced outputs
Full dot VF display
Digital input
Auxiliary input
