1 - 5 of 5 Posts
I have a pair of Seas P18 RNX/P up for sale looking for $100 Shipped. These are in really good shape (almost new) a little rammat goo on the magnets.
Pics:
Discussion Starter · #2 ·
Bump
Will take trades I'm looking for a multi channel line driver or some nice midrangedrivers (2 to 3 inch).
Bump. Good seller. Nice mids.
Specs say 78mm so a little over 3 inches.
Specifications:
Nominal Impedance 8 Ohms
Recommended Frequency Range 40 - 2500 Hz
Short Term Power Handling *250 W
Long Term Power Handling *80 W
Characteristic Sensitivity (2,83V, 1m) 88.0 dB
Voice Coil Diameter 39 mm
Voice Coil Height 18 mm
Air Gap Height 6 mm
Linear Coil Travel (p-p) 12 mm
Maximum Coil Travel (p-p) 22 mm
Magnetic Gap Flux Density 1.0 T
Magnet Weight0.64 kg
Total Weight1.92 kg Voice Coil Resistance 6.1 Ohms
Voice Coil Inductance 1.18 mH
Force Factor 7.6 N/A
Free Air Resonance 44 Hz
Moving Mass 13.1 g
Air Load Mass In IEC Baffle 0.82 g
Suspension Compliance 1.0 mm/N
Suspension Mechanical Resistance 2.53 Ns/m
Effective Piston Area 126 cm2
VAS 21 Litres
QMS 1.52
QES 0.41
QTS 0.32
Frame diameter 176mm
Cut out diameter 145.2mm
Depth 78mm
1 - 5 of 5 Posts
