1 - 17 of 17 Posts
Pioneer DEX-P1R
Used
$150 shipped
Free insured shipping
Pictures: -
Comes with harness, faceplate, trim ring and cage. Faceplate has its share of scratches and the wiring is bit chewed up. Selling cheap!
still available and does everything work well still IE face tilt?, and the cd mechanism ?....Let me know as I may be interested also you still have remote, trim ring, power harness?...
Thanks
Still have it. Everything works. Deck, faceplate, harness, trim ring and cage are all that is included.
If I wasnt spoiled with USB I would get this. I always wanted one of these before they came out with USB on decks.
even still I wish I had the extra to get this.
awesome!
you should dig up the specs cause I remember this had feature list a mile long
You're right... Here's the feature list.
Features:
Supertuner® V™ (RDS + ID-Logic®)
Call Sign (PI) Display
Format (PTY) Display
8 Group Format (PTY) Search, Scan & BSM
Traffic Program (TP) Identification
Traffic Announcement (TA)
Traffic Announcement (TA) Search
Radio Text (RT)
64 Character Message Scrolling Display
3-Message First-In/First-Out Memory
4-Message User Memory
Auto Position Set (APS)
Auto Position Follow (APF)
24-Station (18FM/6AM) Presets
Format-BSM (Best Stations Memory)
Voice Preset Naming (with optional CD-VC50)
AGC (Automatic Gain Control) for Optimum CD Tracking Performance
CD TEXT for Built-In CD Player
Disc Title Memory (48 Discs)
Digital Compression and Dynamic Bass Emphasis
MCD Control of Pioneer P-Bus 6, 12, and 50+1 Disc Multi-CD Players
Disc List
CD Server (CDX-P5000) Enhanced Feature Control
Eject Playing Disc
Music Group Play (10 Groups)
Frequency Play (Most or Least)
Alphabetical Disc List & Play
Sound-Q Circuitry for Superior Sound Quality:
Hi-Bit Legato Link™ Digital Processor
Hi-Volt Component Preamp
Zero-Bit Mute
Hi-Volt RCA Preouts (x3 pair) (Front/Rear + Subwoofer) (4 Volt, <100 Ohm, Gold Plated)
Source EQ/DSP Memory & Source Level Adjuster
AUTO-Flap Motorized Face with 5-step Angle Adjustment
Detachable Face Security™
DFS™ Alarm+
New 23-Key Wireless Full-Function Smart Remote Control (with Mounting Kit)
Multicolor Display with EL Backlighting & Contrast Adjustment
2-line, 32 character Dot Matrix Information Display
15-Band Spectrum Analyzer (5 display modes)
Digital Automatic Sound Levelizer (ASL) with Built-In mic (5-mode)
PREMIER® Two-Year Warranty
Built-In DSP Features
13-Band Graphic Equalizer
4 Factory Presets (Rock/Pops/Vocal/Flat)
2 User Presets
Nuance Control
Auto-EQ - Automatic Frequency Response Calibration System
3 Curves Available (Dynamic/Natural/Mild)
Omni-Directional Microphone (Included)
Standard Mode (Sound Field Priority)
6-Mode Digital Sound Field Control (SFC) (Studio, Jazz, Club, Dome, Concert, Stadium)
Listening Position Selector (4 Mode: Front Left/Front Right/Front/All)
Front & Rear HPF: 50/80/125/200Hz, Level -24 to 0dB, Slope -12/-6/0dB
Subwoofer LPF: 50/63/80/100/125/160/200Hz, Level -24 to +6dB, Slope -18/-12/-6dB
Phase Switch for Subwoofer
Pro Mode (Digital Network Priority)
Time Alignment (0 ~ 160", 0.5" Steps)
Listening Position Selector (3 Mode: Front Left/Front Right/Front)
High HPF: 2k/2.5k/3.15k/4k/5k/6.3k/ 8k/10k/12.5kHz, Level -24 to +6dB, Slope -24/-18/-12/-6/0dB
Mid LPF: 2k/2.5k/3.15k/4k/5k/6.3k/ 8k/10k/12.5kHz
Mid HPF: 40/50/63/80/100/125/160/ 200/250Hz, Level -24 to +0dB, Slope -24/-18/-12/-6/0dB
Low LPF: 40/50/63/80/100/125/160/200/250Hz, Level -24 to +6dB, Slope -36/-30/-24/-18/-12dB
Phase Switch for Low/Mid/High
so is there any inputs that your could use to connect an ipod? If so, im very interested
Remote is necessary for many key functions. Great price on unit if it's in good working order. Pioneer parts can sell you a remote.
If it has a p-bus plug u can use a cd-rb10 to give it a set of RCA inputs. There is a "p" in the model number which usually indicates that it has p-bus.
And just read in the specs about p-bus so it should accept an aux through the p-bus.
You can use a cd-rb10 on this deck. I have a P1R as well and used the aux input once the CD mechanism started rejecting CDs.
1 - 17 of 17 Posts
