1 - 20 of 47 Posts
Polk Audio SR5250 - used - $300
Polk Audio SR104 svc (x2) - used - $250picked up or $250 + shipping - RECEIVED DEPOSIT!
Polk Audio/momo Carbon C300.2 - brand new - $200
Tru Technologies SSLD6i - used - SOLD!
Arc Audio DXE - brand new - $850
Some items are used, some are brand spanking new, never installed.
All items are 100% functional.
Used items have some blemishes but nothing crazy or out of the ordinary given that they were installed/used.
See above.
Prices are "all in" and include paypal and shipping fees except for SR104 subwoofers. See below.
Items will be shipped the next day after payment is received.
By the time i get out of work, get home to pick an item up and drive to FedEx/UPS both places are already closed hence the reson for next day - i'll take the item with me to go to FedEx/Ups right after work.
I'm in Staten Island, NY and local pick is def welcomed.
Here's a group shot and more pics to come in next posts:
Discussion Starter #2
POLK SR5250 - used - $300
5-1/4" aerated polypropylene woofer with UV- and temperature-resistant butyl rubber surround
7/8" ring radiator tweeter with multiple mounting options
die cast aluminum woofer basket
2-way external Zobel crossover network (3100 Hz, 18 dB/octave high-pass and 12 dB/octave low-pass) with four tweeter level settings
power range: 50-100 watts RMS (200 watts peak power)
frequency response: 60-30,000 Hz
sensitivity: 90 dB
top-mount depth: 2-1/4"
2x POLK SR104 SVC - used - $250 picked up or $250 + shipping - DEPOSIT RECEIVED, PENDING SALE
These subs are 30lbs each so shipping will not be cheap here. At least $50 for a pair i'd assume but i need to check on that. Local pick up is the best deal here as shipping will greatly increase total cost.
10" subwoofer with single 4-ohm voice coil
ABS plastic cone
cast aluminum frame
power range: 100-700 watts RMS
peak power handling: 1,400 watts
frequency response: 25-200 Hz
sensitivity: 84 dB
top-mount depth: 7-1/8"
sealed box volume: 1.0 cubic feet
Polk Audio designed their Signature Reference Series subwoofers to deliver superior performance ? you'll hear rich, warm lows, distortion-free clarity, and uncompromising accuracy. Polk packs plenty of advanced engineering into a sturdy, handsome package, so you'll get the impact you want from your system.
The SR104 10" subwoofer features a cast aluminum basket that offers supreme rigidity while virtually eliminating resonances. A sophisticated venting system keeps the sub's inner workings cool and dissipates heat from the voice coils.
The ABS plastic cone provides lightweight resilience and responsiveness, and its inverted arch shape minimizes the flexing which impedes clean bass output. A soft butyl rubber surround gives the cone plenty of room for excursion, while maintaining its shape over time.
POLK / MOMO Carbon C300.2 - brand new - $200
Brand spanking new, only taken out of plastic to be drooled over and then to take these pics. Never seen power, never installed, comes with all paperwork/sticker/manual/wattage caertificate......
As you can see (and as every polk/momo amp) this amp does more then rated.
150 watts RMS x 2 at 4 ohms
220 watts RMS x 2 at 2 ohms
550 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
Maximum Dynamic Headroom (MDH) power supply
requires 4-gauge power and ground leads ? wiring and hardware not included with amplifier
variable high- and low-pass crossovers, 50-250 Hz, 18 dB/octave
subsonic filter at 15 Hz, 24 dB/octave (only operates with low-pass filter activated)
6-way Smart System Protection circuitry guards against power and ground reversal, overheating and shorts, current overdraw, and low impedance
Pre-EQ switch optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers
RCA inputs accept both speaker- and preamp-level input (To use the inputs as speaker-level, you must attach RCA connectors to your speaker wire.)
preamp outputs
optional remote subwoofer level control
dimensions: 13-3/8"W x 2-9/16"H x 9-3/4"D
C300.2 features a Pre-EQ switch, which optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers!
TRU Technology SSLD6i - used - SOLD!
Below are specs on it which probably will not tell you much but if you search around on diyma you'll find a LOT of reviews on this unit from users. There's not a single "bad" or even "it's ok" review, everyone that have/had this unit speak very highly of it. It's probably the best line driver there is that is also a line conditioner (whatever that means lol).
MODEL
SSLD6
TOPOLOGY
Class A/B
CHANNELS
6 CH
FREQUENCY RESPONSE
10Hz ~ 150KHz +/- 0.5dB
FREQUENCY RESPONSE
20Hz ~ 20KHz +/- 00.2dB
THD+NOISE
< 0.009%
S/N RATIO
> 110dB
INPUT VOLTAGE
0.001V ~ 9.2V (Unity Gain)
OUTPUT VOLTAGE
1V:4.5V Ratio (13V Peak)
FUSE REQUIREMENT
1 Amp
POWER SUPPLY
9.5VDC ~ 15VDC
DIMENSION
3.5" x 4.125" x 1.375"
ARC Audio DXE - brand new - $850
Never even taken out of plastic, everything is still sealed.
In the future all audio products will have the flexibility of a fully Digital Control System with the sweet smooth sound and perfect sound stage of an Analog Device. This was our goal when we set out to build the DXE. We use an advanced digital controller to operate all the features of a sophisticated Analog Crossover. The result is the channel tracking and frequency control of a fully digital crossover without the harsh mechanical sound that can accrue. For years home audiophiles have enjoyed Hi End Analog Systems that produce stunning sound stages and smooth harmonics. Now the DXE brings this level of performance to the car with the control of a fully digital crossover.
This truly Audiophile Crossover is coupled with a 5 Band Parametric Preamp EQ with fully balanced output and a Digital Control
Max input level: 8 volts RMS
Input sensitivity: 8V (0dB), 2V (10 dB), 700m(20 dB)
Max output level: 10 volts RMS
Input impedance: 47.5 K ohm
Minimum output impedance: 600 ohms
Harmonic distortion + noise: <.005
Frequency response: +/- 0.2dB
Separation at 1KHz "A" weighted: >78 dB
Signal to Noise "A" weighted: >108dB
Current requirements: 1.2 amps
5 Filters with +/- 15 dB at
20Hz-50Hz with Q of 2,
50HZ-100Hz with Q of 1.4,
100Hz-1KHz with Q of 1.1,
1KHz-10KHz with Q of 1.1,
10KHz with Q of 1.1.
Manual:
http://www.arcaudio.com/product-pdf/DXE_manual.pdf
Bump for some great products. GL with the sale.
that Arc piece is a work of art, ive used couple of them in installs
amazing unit and rare to find
I keep on looking at it and fighting with myself if i should sell it or keep it to begin with lol. I quess it's one of those times where i'll be happy with either outcome.
Discussion Starter #12
Agreement between me and Underdog:
We agreed on $290 shipped for two SR104 subs.
Underdog already send me $100 non-returnable deposit to hold two SR104 subs till Sept 4th
On or before Sept 4th underdog will send the rest of the payment - $190 and will cover paypal fees.
I will ship with FedEx when total of $290 received (current balance is $190)
In other words 2x POLK SR104 svc are sold :)
Yes thats what happened.
Vital is working with me on this transaction:)
Now to get my notes together and head over to XtremeRevolution's sub modeling thread:)
You will like those subs a lot. The sr subs work best in sealed boxes.
My first purchase on this forum. Vital was a pleasure to do business with and very, very helpful in telling me some more about the SR5250s.
That Arc DXE would be great to have. I've wanted one for years but the lack of some features is just keeping me from buying it. GLWS.
Discussion Starter #20
^^^ I feel ya, you'd think an almost $2,000 unit would have TA lol. Then again i'm selling for waay less so even without a TA it's a sweet unit and a great deal imo.
1 - 20 of 47 Posts
