1 - 17 of 17 Posts
Product Brand & Model: Precision Power (PPI) DCX-730
Condition of all items: Used. Visual condition is 9/10. Display does not work, Windows software required to tune via USB port.
Total Price: : $120/shipped
Shipping Terms: : Free shipping to lower 48 states
• 6-channel fully digital sound processing
• 24-bit digital signal processor (DSP) engine
o 7-band fully parametric equalizer
o Independent EQ settings for each channel
o Fully variable 3-way crossover
o Selectable 6, 12, 18, or 24 dB/octave crossover slopes
o Variable 0-70 msec time alignment for each channel
o Parametric Q BASS bass boost
• Wired controller with blue backlight
• 2-line x 16-character LCD display
• 5 user presets
• USB connection for PC updates
• 2-6 channels input/2-6 channels output
• Fully configurable input-to-output mapping
• Adjustable 250mV-12V input sensitivity
• 7.5V RMS preamp line driver
• Remote turn-on with programmable delay
• LED power & output clipping indicators
• Includes in-dash trim ring
Specifications
• Frequency Response: 20-20,000 Hz
• Signal-To-Noise (S/N) Ratio: >85 dB
• Total Harmonic Distortion (THD): 0.05%
• Input Impedance: >10k ohms
• Input Sensitivity: 250mV-12V RMS
• Output Level: 7.5 volts RMS
• Dimensions (main unit): 6 1/4" L x 5 1/2" W x 1 5/8" H
• Dimensions (remote unit): 7 3/8" W x 1" H x 6" D (half-DIN)
There are several versions of software that work with this unit. I haven't run the software since upgrading to Windows 7 (been a few years). If there is a serious buyer, I will install and demo the software via Skype or something...but if I'm going through that trouble no deals will be made. $120/shipped firm if you want to see it up and running.
I have no idea what other display it will work with. It is a serial port connection (like an oldschool mouse or keyboard). Regardless, the software is far superior compared to tinkering with all the menus and submenus.
Yes it would but all of these processors suffer the same fate so any display you find will likely have the same issue unless it is brand new.
Discussion Starter · #11 ·
I have a copy of the software. I've verified it works from Windows Vista. I couldn't get the installer to run on my Win7-64 machine but I can send it to anyone interested if they want to verify the software works before purchasing.
Sale pending at the moment with one other person interested.
Screenshot below shows the software on the left and TrueRTA taking direct readings from the unit on the right.
Discussion Starter · #15 ·
No, I need to clean out the garage....been holding on to this stuff too long. PM me if you are interested and I'll put you in line. Also check out my other items up for sale.
1 - 17 of 17 Posts
