1 - 16 of 16 Posts
CS 265 PROFI - Rainbow Profi 6.5" 2-Way Component System $400 + Shipping
Peak power: 180 Watt
Power rating: 120 Watt
Minimum amplifier power: 75 Watt
Sensitivity: 90 dB 1W
Frequency response: 39 - 35.000 Hz
Impedance: 4 Ohm
Slope: 2 x 18 dB
Crossover frequency: 2.400 Hz
Thermal protection: HALO + PTC
Woofer
Mounting depth: 66 / 64 mm
External: 167 / 190 mm
Installation: 145 mm
Fastening: 156 mm
Tweeter
Mounting depth: 20 mm
External: 51 mm
Installation: 44 mm
Rainbow iPaul 2.400 $250 + shipping
Stereo 4 ohm: 2x130 Watt RMS
Stereo 2 ohm: 2x200 Watt RMS
Mono 4 ohm: 1x400 Watt RMS
THD+N: <0,04%
Signal-SNR: >95 dBA
Frequency Range: 10 Hz-35kHz
Input sensitivity Level In: 250 mV-6
High Pass/Subsonic - Front: 15 Hz - 500 Hz, 12 dB
Low pass Rear: 50 Hz - 5kHz, 12dB
Bandpass Rear: 15 Hz - 5 kHz, 12 dB
Bass Boost: 0/6/12 dB
Phase Shifter: 0-180 degrees adjustable
Remote Control (5m Cable): Level and phase adjustable
Operating: 11 V-16 V DC
Weight: 5.8 Kg
Rainbow iPaul DM2000 $375 + shipping
Power Output at 4 Ohms: 360 Watts RMS
Power Output at 2 Ohms: 730 Watts RMS
Power Output at 1 Ohms: 1000 Watts RMS
THD: <0.02%
S/N Ratio: >95dBA
Frequency Response +/- 3dB: 10Hz-250Hz
Input Sensitivity: 250mV - 6V
Variable Subsonic Filter
Low-pass Filter: 50Hz-250Hz, 24dB/Oct
Current Draw: 90 Amps Maximum
Dimensions: W x H x D:415 x 60 x 250 mm
Morel Ultimo SC Subs 10" $300 each + shipping
Power Handling: 600 WRMS
10" inich
Ohm: 2 Ohm
Transient Power 10ms: 2000W
Sensitivity: 90.5dB
Voil Coil Type: Single Voice Coil
Voice Coil Diameter: 5.1"
Mounting Depth: 5.38"
Fox Acoustics F150 sub box $130 each + shipping
THIS ENCLOSURE FITS 2004-2011 FORD SUPER CAB
AND 2004-2008 SUPER CREW TRUCKS.
!! does not fit the 2009-UP super crew !!
2-10" SEALED DOWN FIRE
12" IS NOT AVAILABLE.
INTERNAL AIR VOLUME: .65 per side
DIVIDED: YES
SUB SIZE: 10"
HOLE SIZE: 9.125"
MOUNTING DEPTH: 6" WITH A 6 INCH DIAMETER MAGNET
CONNECTORS: 2 SCREW MOUNTED SPRING TERMINALS
FLOOR CLEARANCE: 1.5"
DOES NOT FIT THE F-250/350 TRUCKS
JACK AND TIRE TOOLS MUST BE RELOCATED
SUB ENCLOSURE IS SPRAY COATED WITH BLACK LINE-X BED LINER.
I had a set of these Rainbow components, the phase plug version. Very nice sounding drivers.
1 - 16 of 16 Posts
