SEAS LOTUS SW250/1 10 INCH SUB
ITEM HAS NOT BEEN PLAYED, IN PERFECT CONDITION. STILL HAS ALL ORIGINAL PACKAGING
$399
I WILL SHIP USPS WITH TRACKING. PAYMENT WITH PAYPAL OR I WILL DO POSTAL MONEY ORDER. BUYER PAYS SHIPPING. $25 FOR U.S. IF YOU ARE INTERNATIONAL I WILL GET YOU A QUOTE
Seas is superior high end audiophile sound quality products. 25 cm featuring low distortion. If you want a realistic sound of lowest frequency range. Aluminum cone. Lead out wires are integrated in spider for noise free sound at large excursions. Wide rubber surround for optimum performance over various temperature range. Stable injection metal basket to keep parts aligned in normal or extreme conditions. High temperature voice coil with kapton former. Screw terminals give excellent contact with speaker cables.
Nominal Impedance: 4 ohm
Recommended Frequency Range: 30-500 hz
Short Term Pwr HAndling: 400 watt
Long Term : 150 watt
Sensitivity: 91.5 db
Voice coil diameter: 52mm
Voice coil height: 32mm
Air Gap Height: 10 mm
Linear coil: 22 mm
Maximum coil travel: 35 mm
Magnetic gap flux density: 0.66
Magnetic gap flux height: 5.80 kg
total weight: 6.70 kg
Voice coil resistance: 3.2 ohms
voice coil Inductance: 6.39 mh
force factor: 14.0 n/a
free air resonance: 31 hz
moving mass: 139 g
air load mass in IEC baffle: 3.73 g
suspension compliance: 0.2 mm
effective piston area: 346 cm
VAS: 31 lites
QES: 0.46
QTS: 0.43
$399
Linear coil: 22 mm
moving mass: 139 g
VAS: 31 lites
QES: 0.46
QTS: 0.43
