1 - 5 of 5 Posts
1. Product: Stereo Integrity Magnum - V.3 D2 (12 spoke basket)
2. Specs: Can't find the full spec sheet online, it's 1000wrms, d2
3. Description/Condition: This sub is in absolutely fantastic condition. Well loved, never abused. It went straight from the packing box I received it in directly into a sealed fiberglass enclosure - it has barely seen daylight. It was used for about two years powered by a cadence daytona 1000.1, gains were never set past 2/3 and bass boost was used with caution. The only "blemish" (if you can even call it that) is that the vanity ring has slight marks in the mounting holes from when it was mounted. 9.9/10 cosmetic 10/10 function.
4. Price: $160 + shipping or $200 shipped. Whatever is cheaper for you.
5. Pictures:
Discussion Starter · #2 ·
1. Product: old zed-built Lanzar opti 500.2
2. Specs:
RMS power ratings
2 x 250W @ 4 ohms (<0.05% THD)
2 x 400W @ 2 ohms
1 x 900W @ 4 ohms bridged
S/N Ratio: -102dB
Dimensions: 19.7" x 11" x 3" (50cm x 27.7cm x 7.6cm)
Weight: 22 lb. (10 kg.)
Built by Zed Zudio
3. Description/Condition: the top edges of the heat sync are scraped up badly, and a few other minor cosmetic scrapes. it also needs 3 torx bit screws to hold one of the side panels on- 5/10 cosmetic. it works perfectly fine, no issues 10/10 performance
4. Price: : $150 shipped or $120 local pickup it's large and heavy so shipping is going to be pricy
5. Pictures:
1. Product: Cadence Daytona 1000.1
2. Specs:
SPECIFICATIONS:
4 Ohm RMS Power: 1 x 25 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 750 Watts @ 13.8 Volts
1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
2 Amps Bridged: 1 x 2000 Watts
Frequency Response: 10Hz - 500Hz
S/N Ratio: >100 db
Damping Factor: >500 @ 100Hz
Minimum THD: <0.03%
Input Voltage: 200 mV - 6 Volts
Dimensions: 11" x 9.5" x 3.5"
FEATURES:
High Speed Mosfet Power Supply
Bi-Polar Japanese Sanken Output Devices
Double Sided Copper Rail PCB Architecture
24 dB Crossover Circuitry
Low Pass Crossover: 35Hz - 250Hz
Subsonic Filter: 10Hz - 50Hz
Bass Boost Equalization: 0-18db @ 45Hz
Lucite Encapsulated Large 2 and 4 Gauge Terminals
Dash Board Bass Remote
Dual-Amp Bridging for Double the Power @ 2 Ohms
Master/Slave Control
Adjustable Phase Control
Soft Start Mute & Delay
Tiffany Style RCA Line-In/Line-Out Jacks
24db Crossover Roll Off
Blue Edge-Lit Acrylic Side Panels and Light Bar
2 Year Warranty
3. Description/Condition: Was using it to power a SI magnum v2 12" for about two years. Amp was in a clean trunk, never beat on. It has some minor scratching and two letters are missing (one C from cadence, and the Y from technology), but it's largely a very clean amp - about 8.5 or 9 / 10. Functionally, it's 10/10 and works like the day I bought it. You have to look pretty hard to find blemishes, they're relatively minor and on the bottom of the amp.
4. Price: : $120 + shipping or $150 shipped, whatever's cheaper for you
5. Pictures:
PS - the mounting feet look bent, they're not - chrome is incredibly difficult to photograph accurately.
1 - 5 of 5 Posts
