1 - 9 of 9 Posts
Tsunami RM9100 Digital Volt Meter display and fuse status.
New, just not in the package.
$25 plus shipping.
USPS should be $5 for priority.
On the backside of the unit are two small mounting holes you can put screws into that protrude out 1/2" if you cut those off your total depth would be 2" if you leave them your total depth is 2.5".
I guess I'm just confused about how it knows that a fuse is blown. I'm still interested, I just don't get what is involved with the installation.
Discussion Starter · #7 ·
The best I could recommend at this point is emailing Tsunami, I have not been able to locate any install or wiring info on the web on this item. I may have the original packaging at my other house, just not sure when I will be able to get over to check.
Ok, so I looked around a bit and I think this is an RDS9100 and not an RM9100. The RM9100 was just a display and cable that plugged in to the FDB9104-AGU fuse holder. The RDS9100 is a universal unit that comes with the adaptor box (which I see in the picture). I guess you just run a small primary wire from the output of the fused connection to the inputs of the adaptor box. Can you confirm this difference based on what you have?
If it is indeed the RDS, just PM me your PayPal address.
1 - 9 of 9 Posts
