1 - 20 of 26 Posts
Product Brand & Model: Various MDF speaker rings
Condition of all items: As the title states, I have a couple of MDF speaker spacer rings of different sizes and thicknesses that I didn't like the way they came out. Some parts are sanded down more than others (especially on the inner diameter of the ring) so there are some weird nicks which makes the inner diameter not exactly a perfect circle. They aren't perfect but they should work as intended. If you'd like to see any more pictures let me know. The rings pictured are:
1 pair of 10" rings 3/4" thick - ID: 9.25", OD: 10.25"
1 pair of 10" rings 3/4" thick - ID: 9.375", OD: 10.625"
1 pair of 8" rings 3/4" thick - ID: 7.25", OD: 10.75"
1 pair of 8" rings 3/4" thick - ID: 7", OD: 10.5"
1 pair of 8" rings 3/4" thick - ID:7.125", OD :8.25"
1 pair of 8" rings 3/4" thick - ID:7.5", OD: 9"
1 pair of 8" rings 3/4" thick - ID: 7.125", OD: 8.625"
1 pair of 8" rings 3/4" thick - ID: 7", OD: 8.5"
1 pair of 5.25" rings 1/2" thick - ID: 4.5", OD: 5.25"
1 pair of 5.25" rings 1/2" thick - ID: 3.875", OD: 5.4375"
1 pair of 4" rings 1/2" thick - ID: 3-5/16", OD: 4.5"
2 pairs of 4" rings 1/2" thick - ID: 3-15/16", OD: 5"
2 pairs of 4" rings 1/2" thick - ID: 3-15/16", OD: 5-3/16"
1 pair of 4" rings 1/2" thick - ID: 3.25", OD: 4.5"
10" rings pair - $11 shipped
8" rings pair - $9 shipped
5.25" rings pair - $4 shipped
4" rings pair - $3 shipped
Well the outside diameter is 10" or more but the inside diameter is a little more than 7" so realistically only 8" drivers would fit which is why I have them as 8" rings. Hope that answers your question.
Updated list of speaker rings still available:
are sold now. Rest still available.
I got 2 pairs of 6.5 inch speaker rings, 1/2" thick MDF with the dimensions of ID:5.375" and OD: 7.375". Letting them go for $7 a pair shipped if anyone is interested.
Discussion Starter #13
This is what I still have available for those interested:
i got my ring set and they look good
Discussion Starter #18
Man,i need 2 for my volvo/dynaudio..8's..now if i knew the.sizes.
Is the speaker your talking about like this:
Volvo C70 OEM Dynaudio Hi Fidelity 8" Speaker Woofer | eBay
In the description it says it measures 9-1/4" on the outside and from the 2nd pic it looks like there is about an inch of mounting space for the speaker which would give a cutout diameter of 7-1/4" (that's my guess). Better yet would be if you were to actually measure the speaker yourself. The outside diameter would be easy to measure, the inside diameter a little more difficult depending on the measuring materials available to you. Either way you should be able to get a ballpark figure of the actual measurements.
i'm going to need a pair of ARC10's, L6's, and L3's... would you be able to make me the rings and how much shipped to Vegas 89178?
1 - 20 of 26 Posts
