ITEM BRAND & MODEL #: Zapco ADSP-Z8 IV-8 (8 Ch. DSP with 8 Ch. Amplifier)
CONDITION:
Used - 9.5/10
PRICE: $850 O.B.O.
SHIPPING:
Included
ADDITIONAL INFORMATION: Box, manuals, display and all cables included.
  • DSP Processor: Cirrus Logic CS47048
  • Power: 150 MHz/32 bit/48 KHz
  • 8-Channels
  • ADC: Cirrus Logic CS5368 24 bit/192 KHz
  • ADC Dynamic Range/THD: 114 dB/-105 dB
  • DAC: Cirrus Logic CS47048 32 bit/192 KHz
  • DAC Dynamic Range/THD: 108 dB/-98 dB
  • Low level (Pre)/Sensitivity: 8/1-5 VRMS
  • High Level (Spk In)/Sens.: 6/2-20 V
  • AUX Inputs/Sensitivity: 1/0.2-4 VRMS
  • Optical IN: 24 bit-192 KHz
  • Freq. Response (-3dB): 10 Hz - 22.5 KHz
  • S/N Ratio only DSP Digital Input: 110 dBA
  • S/N Ratio only DSP Analog Input: 106 dBA
  • S/N Ratio Amp + DSP at max. power: 95 dBA
  • THD+N only DSP Digital Input: 0,002 %
  • THD+N only DSP Analog Input: 0,005 %
  • THD+N Amplif. + DSP Analog Input: 0,07 %
  • Crosstalk at 1 Khz only DSP: 90 dB
  • Crosstalk Amplifier + DSP: 45 dB
  • Amp Power @ 4Ω: 8 x 80 watts
  • Amp Power @ 2Ω: 8 x 120 watts
  • Amp Power @ 4Ω Bridged: 4 x 240 watts
  • Amp Power @ 4Ω: 6 x 80 + 1 x 240 watts
  • Amp Power @ 2Ω: 6 x 120 + 1 x 240 w. (4 Ω)
  • F/R EQ: 1-6 ch Gr. & Par./31 poles
  • Effect EQ: 7-8 ch Gr. & Par./11 poles
  • Mute/Solo: Yes, each channel
  • Time Align. (Range/Steps): 0/15 ms / 0.02 ms
  • Max Delay (Cm/Steps): 515 cm / 0.68 cm
  • Polarity: 0/180°
  • Display (included): 1” LCD
  • Display (optional): 3” LCD Touch-Screen
  • Bluetooth Digital Streaming
  • PC/Display Connection: USB/6-pin Mini DIN
  • Unit Dimensions: 222(L) x 230(W) x 52(H)
  • Display Dim.: 111(L) x 49(W) x 16(H)
PICTURES:
Brown Handwriting Post-it note Font Rectangle
Brown Rectangle Material property Font Office equipment
Brown Rectangle Font Box Packaging and labeling
Rectangle Gadget Font Composite material Metal
Netbook Gadget Font Laptop accessory Rectangle
Audio equipment Gas Electronic device Font Display device
