1 - 7 of 7 Posts
Amp works perfect and is rock solid, but there are a couple of dings on the heat sinks from the original owner. Will send pictures tomorrow. Priced accordingly.
$400 shipped.
Features and Functions
  • Mono Class D Linkable, bass amplifier,
  • Stable into 1 Ohm (2 Ohm w/2 amps Linked/Strapped)
  • PWM MOSFET power supply
  • 24 dB Variable low pass (LPF) crossover
  • 12 dB Variable bass boost equalization
  • 0 – 180 degree variable phase shift
  • 24 dB Variable subsonic filter
  • Selectable master and slave operation for Linked (strapped) amplifier operation
Specifications
  • Power @ 4Ω: 800 watts
  • Power @ 2Ω: 1400 watts
  • Power @ 1Ω: 2100 watts
  • Linked @ 2Ω: 3600 Watts
  • THD @ Rated Power < 0.05%
  • Signal to Noise Ratio > 90dB
  • Damping factor: > 350
  • Efficiency: 86%
  • Input Sensitivity .2v to 8v
  • Dimensions in mm: 190(W) x 62(H) x 450(L) Overall: 190(W) x 62(H) x 486(L)
Discussion Starter #2
Pictures: You can see there is a nick in one of the fins, and some discoloration at the top. So if this is goign to be in a show car i would pass, but for 99% of the folks out there this is a solid amp and still looks great. I am only selling because i switched subs and i think . this is more power than my 8" evos want. Plus i found a MINT a600.2 that i have been looking for for years.:)
1 - 7 of 7 Posts
