What resolution and refresh rate is the monitor?
What resolution and refresh rate is the monitor?@BobTheBirdTurd I really don't have a budget, I don't want to spend what I can buy a new one for. How's 800-1k would that get it back to date? This is a different language to me I don't know anything about it my son is a senior he claims to know about it and definitely knows more than me but I'd like to get whatever you'll recommend to get it going. Thanks for all your help.
Thanks, Shannon
Sent from my SM-G960U using Tapatalk
Ok - so in order to run 1080p at Ultra with anything over 60-80 frames per second you are gonna need a current gen Video Card. Since the Monitor is "FreeSync" (an AMD technology) sticking with AMD video cards will mean the most compatibility and you the Omen is already AMD anyway so it makes sense to stay AMD.
While I agree with all of this it has been my SOP to do 64GB and have the capability to do Sync for gamers who get into streaming on Twitch and YouTube so when they stream NFS:Unbound or Forza they get the highest quality stream. But, yes, in PvP online battles the suggestion to disable all that for the least lag is always a good idea.Post above by @daloudin is great, detailed and makes sense, yet I’d adjust that build it. Why? Well 64GB is really overkil, that’s workstation amount of RAM, 32GB is more than enough even for current games at 4K, better IMO to search for faster 4x8GB. About SSD, well if current 256GB doesn’t limit that much, then going over 1TB surely isn’t necessary. I’m doing fine with just 500GB. So we can cut quite a few bucks without any real disadvantages. Vsync, FreeSync etc. Aren’t good for games like CoD, as those increase input latency, fine for role play games, but bad for first person shooters, especially in online mode.
@BobTheBirdTurd he's got multiple M.2 headers so he can clone without the adapter.@daloudin clearly just doesn't know car audio. I cannot disagree with anything in his post, it's sound advice. As the other 2 posters have mentioned, a 2TB NVMe and 64GB of RAM may be a bit overkill, but those 2 items don't add much to the cost, you could maybe save $100 by going 1TB and 32GB which would be plenty for this rig to live out the next couple years. At that point, the CPU and motherboard will need to be put out to pasture. One reason I would do a smaller NVMe as smaller drives perform better than larger ones, you won't notice the difference unless you are running bench marks, but there is and IO difference.
For those saying buy faster memory, that's all fine and dandy when you have a custom motherboard that is rated for higher than standard speeds. 3200 memory is what that memory is designed to run at, anything over that and it's overclocked. For stability, I would stick with 3200.
For GPU, I agree with sticking with AMD.
Unless you have skills with reloadin your OS, I would pick up one of these so that we can clone your drive to the new one. This will make it easy to the do the drive swap. If you don't know to do this, I will make you a guide or walk though using a free program called Macrium.
https://www.amazon.com/Sabrent-Type...aWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1
Correct - here's the passmark G3D results for both and the OP can make that decision.He was looking to stay under $1K, so you might want to drop to a 6800XT, I picked one up from Microcenter last week for $512.
6800XT has great price-to-performance.
That is as far as I would push that motherboard and processor. These components will take you as far as that system can go and as mentioned should be good till PCIe v5 or the next iteration of Bus technology comes out in the next 2-3 years.So the 4 items @daloudin listed for 1235.00 is that my best bet? Is that all I need? If so will the computer be back to date and able to play any games?
Thanks for all the help.
Thanks, Shannon
Macrium is fine and especially if @BobTheBirdTurd is willing to walk you thru the process but I just wanted to point out that Samsung drives come with their own "Samsung Data Migration" software as well.Before you do the drive swap, I can walk you through the cloning process before you take anything apart or even crack the case open. You will need a product call Macrium Reflect. You can get the free trial and it will work for what your trying to do.
The mineral oil builds are scary - the pumps are higher pressure contributing to leaks and depending on the purity of the oil you use some of them were proven to have a flash point under 500⁰ F and contributed to some serious fires.I remember seeing a few rigs like that.
When I got into PC modding for a time water cooling was starting to take off.
Water cooling was difficult to do and leaks were common. Now you can buy an AIO and be done.
Do you remember the mineral oil PCs? I think some still build them.
When I did dabble in water cooling my go-to place was Performace PC
For modding Bit-tech was my go-to place for inspiration.
After reading this thread I popped over there to see if the site still exists and it does. The build there is still awesome.
The UK's leading source for Hardware and Games reviews | bit-tech.net
The latest technology, hardware and game reviews and case mods. The latest news headlines from the hardware and gaming industries.bit-tech.net
Yeah - the one we built was massive overkill created before calculating the dissipation required so it was a SNAFU. It can be done and the tech has come a long way since then...Interestingly, Linus from Linus tech tips did a review of a Peltier CPU cooler; it didn't do so well.
Intel makes a product that regulates the temp to prevent freezing.
Here is a cool master using the Intel Cryo Tech
