1 - 3 of 3 Posts
Hi
Looking for help on the hump around 400. Is this a peak at 400 or Dip at 600 hz.
The crossovers is HPF 315 hz and LPF 3.2 khz.. 24 db/Oct.
I have added damping inside the pillars to control resonance but did not make any difference....should I add more layers of fiberglass from the inside of pods?
Measurement in Blue is before damping and red after adding damping.
The pods are sealed.
Sent from my SM-G950F using Tapatalk
Since you have a more linear response from 600hz to 3khz, I'd treat 400hz as a peak and lower that area to be equal to the rest. You can try stuffing, but if that doesn't help, hit it with EQ.
Thanks for the clarification. I will try stuffing and see if that helps. Else eq.
1 - 3 of 3 Posts
