Very clean-sounding and efficient amp. Physical condition is a bit rough, but everything works fine. Just the amp is included, no box, manual, accessories, etc. Missing the placard that went over the fan. Most of the flaws could be polished out if desired. I've set the price based on the rarity, but I'm not firm. Shipping and fees are on the buyer. More pictures in replies.
The most flexible amplifier in the Ultra line-up can grow with your system. From running a Front system and sub, it can progress to front system bridged or all the way to full Active mode for a 2 way front speaker system. The inbuilt crossovers make changing your system layout a breeze. Summed Mono preouts allow easy connection of a sub amp as your system grows. Sub remote capable for Subwoofer control. High Level input for interfacing with your Factory Stereo.
Specification
4 x 150W at 2 ohms / 4 x 100W at 4 ohms / 2 x 300W Bridged
Technologies
Smart Switching – Automatically routes the signal
Parametric EQ (P Sub/ P5) – Gives full adjustment of the subwoofer sound
Thermal bias tracking – Eliminates distortion
Flexi-mount system – For easy installation
Vari-speed Thermal management – Quietly keeps everything cool
DC Sub level control – Eliminates noise pickup
Features
Power Levels [2 Ohms] – 1 x 150W
Power Levels [4 Ohms] – 1 x 100W
Bridge – 2 x 300W
THD – < 0.1%
Signal to Noise Ratio – 100dB 'A' Wtd
Input Sensitivity [Volts RMS] – 0.3 ~ 4 Volts
Current Draw @ 4 Ohms – 45 Amps
Fuse Rating – 40 Amp
Crossovers HP [All Continuous] - CH 1 & 2 – 30 – 6000 Hz
Crossovers HP [All Continuous] - CH 3 & 4 – 20 – 200 Hz
Crossovers LP [/- Module] - CH 3 & 4 – 60 - 6000 HZ
Dimensions H x W x D [mm] – 38 x 450 x 217
Weight [Kg] – 3.0
