Hello!
So you today is a rare Genesis Profile Sub Ultra in amazing condition. The box has been moved around over the years, but always kept in temperature controlled rooms! It will also come with a sub remote control from Genesis!
Here is some info on this amp:
Description
Handcrafted in the UK. Genesis products are designed and manufactured in Southend on Sea, UK. Profile Sub Ultra Recently re-launched with re-designed power supply for improved reliability. Built to drive modern high power subwoofers to their limit, Profile Sub Ultra delivers up to 1000 watts of clean pure power. Optional Remote Level control for easy level adjustment. Separate Subsonic and Low pass filters for total control. Parametric EQ allows tuning of sub system to suit all music styles. Class G keeps everything cool.
Specification: 1 x 550W at 4 ohms / 1 x 1000W at 2 ohms
Features & details
Description
Features & details
- Technologies:
- Smart Switching - Automatically routes the signal Parametric EQ (P Sub / P5) - Gives full adjustment of the subwoofer sound DC Sub level control - Eliminates noise pickup Flexi-mount system - For easy installation Vari-speed Thermal management - Quietly keeps everything cool Thermal bias tracking - Eliminates distortion
- Features:
- Power Levels [2 Ohms] - 1 x 1000W Power Levels [4 Ohms] - 1 x 550W Bridge - N/A THD - <0.1% Signal to Noise Ratio - 100dB 'A' Wtd Input Sensitivity [Volts RMS] - 0.3 ~ 4 Volts Current Draw @ 4 Ohms - 55 Amps Fuse Rating - 3 x 40 Amp Crossovers HP [All Continuous] - CH 1 - 20 - 200 Hz Crossovers LP [/- Module] - CH 1 - 50 - 200 Hz Parametric Equaliser - Yes Dimensions H x W x D [mm]* - 38 x 450 x 217 Weight [Kg] - 3.0
- Our Profile and Profile Ultra series balance the need for compact chassis, high efficiency and class leading sound quality. The low mounting profile lends this series it's name, and allows installation where other amplifiers won't fit. Vari-speed thermal management and innovative Class G technology yield excellent power outputs in small spaces with freedom from overheating, an all too common problem with other compact amplifiers. As you would expect from Genesis the sound quality and features are second to none.
