Yep, you got me! Actually, I painted them white, and then sanded the sides back down to plywood, so only the inside edge of the hearts is white!look... he painted the hearts inside the box too!
It’s amazing how much of a difference just rounding off the edges dresses a piece up. Looks great!The amp will go here next to the spare:
Thanks!It’s amazing how much of a difference just rounding off the edges dresses a piece up. Looks great!
If you have the information handy, what are the specs on the round over router bit you used?
Not much sanding, it comes about pretty smooth... With this hard plywood, I have better results when I take a couple passes and only press the wood gently into the bit, even with just a 1/4" round over.Did you have to do any significant amounts of sanding after it was ran on the router? Last time I did it, even taking my time with a pretty fresh bit it splintered a good bit to clean up.
Sent from my SM-G955U using Tapatalk
That's a big boi, I'll have to keep that in mind next time. ThanksNot much sanding, it comes about pretty smooth... With this hard plywood, I have better results when I take a couple passes and only press the wood gently into the bit, even with just a 1/4" round over.
Where it get's really hairy is with the bigger bits! Lol. This a 1.25" bit...
Haha thanks!!That's a big boi, I'll have to keep that in mind next time. Thanks
Only slightly jealous of the build quality of the box
