Hi so I just purchased a
JL Audio 1000/1 v2 Amp, Runs about 1000-1300 wrms I believe it puts out more then 1000 easy.
I had a kicker 15 inch L7 Rated at 1000 Wrms, and 1500 peak, it blew the subwoofer after about 2 months of use, not even on full gain!
I was wondering what a good sounding 1500-2000 wrms 12 inch subwoofer would be, I could also go 2x 10 inch 750-1000wrms subs, But I want to keep my wrms atleast 1500+ for woofers so they don't blow.
The amp puts out 1000wrms or more at all times no matter what ohms subsa re at/voltage is coming from battery.
So whats going to sound best? Whats going to sound loudest?
I mean 10s probably wont hit the lows I want to hear as well as a 12 but will be a bit tighter.
Also sealed or non sealed depending on the sub you recommend? Thanks
This is going in a Dodge Ram 1500 2010 Sport Edition. Its going to sit where the seat is after the seat is folded up. if 2x subs will go on pass side if 1 sub will go on driver side.
Should I face the sub towards driver or towards box of truck?
