If you would like to learn this I highly recommend this site - WIRE
No. That's not what fuses are for.should I run the inline fuse holders with a 150 amp fuse within 1 foot of the battery and then fuses to match the amp fuses (80 amp for one amp and 60 amp for the other) or all three with 150 amp fuses?
Thanks!If you would like to learn this I highly recommend this site - WIRE
No to which one?No. That's not what fuses are for.
This makes alot more sense than the wire website, thanks! I'll have to try to read the wire page again that wa posted earlier- thanks!Getting ready to put in a new system myself and I've seen lots of different ways to go about it. The way I see it, fuses are for protection, so...
What I'm doing:
Add up all the fuse ratings of your amps.
Figure out the amp rating of your power wire.
Whichever is lower, that's the size fuse you go with. This will insure that nothing (wire or amps) burns up before the fuse does. Ideally the combined fuse total of your amps should be less than that of the wire. If it isn't, I would look at going with a bigger/better wire to get it that way. Always best to error on the side of caution!![]()
well why didn't you just say that??It might make more sense, but it's not correct.
Fusing is for wiring. Period. The size of the fuse should be chosen to adequately protect your wire. For 4ga, it can be 125A. Or it can be lower. It can't be higher.
The fuses on the amps are for amps. Period. If they're fused by the manufacturer, then they're all set. That fuse rating has NOTHING TO DO with how much current that amp will actually draw under normal operating conditions. It was determined by the manufacturer to be the right size to protect it from bursting into flames. Some amps (not generally in car audio) have several fuses inside of them to protect certain circuits from taking out certain other circuits. Some even have specialty circuits that are more effective (ie. faster) than fuses for added protection. Either way, the bottom line is to ignore your amp fuses. They don't provide any useful information to you.
It's really a pretty simple concept, IMO:
1. Choose wire size based on how much current you expect the amplifier(s) to draw. This is sometimes on the spec sheet. When it's not, it can be estimated by dividing the nominal power rating by about 10 or 20 (or even more if it's a class D amp). The answer you get is already a HUGE overestimate of current requirements, so you shouldn't feel like you need to add more overkill to this number. You can if you want, but you don't gain anything.
2. Once you have decided on the wire size, go to the fuse chart on bcae1 and buy that fuse (or lower).
That's all you really have to do.
would this be safer than individually fusing the 2 lines after the dist block? wouldnt this "choke" the amount of power going through the 4g?You have to fuse the smaller wire with smaller fuses. But there is an acceptable shortcut. You could undersize your main fuse.
For example, if your main wire is 4ga and it splits to three 8ga wires, you could put a single fuse on the main line sized according to what 8ga calls for. Then you wouldn't have to individually fuse the 8ga lines.
can fuse the 4ga for 125A and then the individual 8ga lines at the distro or do like Mark suggested with a smaller fuse at the 4ga. you can always fuse smaller and not hurt anything.would this be safer than individually fusing the 2 lines after the dist block?
It could make it blow, but this is typically not the case.can fuse the 4ga for 125A and then the individual 8ga lines at the distro or do like Mark suggested with a smaller fuse at the 4ga. you can always fuse smaller and not hurt anything.
BUT! if you fuse the 4ga wire for the 8ga distro wires. you might be under fused for total amperage draw. This wont hurt anything, but it will make the fuse on the 4ga keep blowing. you need to work that up in your design.
just wanted to make sure he understood the posibility. if he is on the edge with the 8ga, then 2 8ga runs could support more current than 1 4ga. would this happen very often, no. that is why I said he needs to work out his current demands.It could make it blow, but this is typically not the case.
okay, but is it a safety concern to fuse the 8g individually immediately after the dist block? or do I HAVE to have a fused dist block? I'd prefer to not be constantly replacing fusescan fuse the 4ga for 125A and then the individual 8ga lines at the distro or do like Mark suggested with a smaller fuse at the 4ga. you can always fuse smaller and not hurt anything.
if this will eliminate complication i don't mind running all 4g, but if it complicates things by changing wire size then I'll just run all 4g. if i run all 4g then I only need to fuse once at 125a within 1 foot of the battery and then I'm done, right? It was suggested by another user that I should fuse multiple amps individually...this is also why I jsut run the same gauge wire across all paths. makes things simpler.
