Which one should I get? What the difference between a 6x9 and 6.5?
what the difference sound wise? is the 6x9 going to have less vocal and more midbass?The GS line is below the GB line. It's not only a what you can fit argument but a budget argument as well. If you can stretch to the GB60, can fit it, and are set on audiofrog, then GB60 it is.
This what i wanted to hear. i like the thump of a nice 6x9 up front but also want it to be able to get loud. plus the 6x9 plays down to the 42 hz and the 6.5 only plays down to 60hz. im just trying to understand why cars come with 6x9s and a sub but Audiofrog want you to use the gb60.The designer recommends the GB60 over the GS690.
Says it has lower distortion and has as much displacement potential based on cone area and xmax.
In a 2 way I'd definitely go with the GB60, but I'm not so sure for a 3 way.
The GS690 actually has a higher output potential with the right high pass filter.
The GS690 is 92 db at 2.83V/1M with 100 rms of power handling so a pair can hit 115 db without factoring in power compression.
The GB60 is 88 db at 2.83V/1M with the same 100 rms of power handling so a pair can hit 111db without factoring in power compression.
Then they both have a max of 300 watts so unless the GB60 is a good deal more efficient the GS690 has more output potential with the right highpass filter.
The distortion difference between the 2 ran purely as midbass may or may not be be audible depending on the install and the listener. Many of us can't notice distortion easily at those frequency ranges, in fact it may still sound clean but a little louder.
I believe both drivers are 4 ohmI’ve had both and am currently using the GS690’s. The GS690 has a lower impedance, so it gets more power from my current amp: Helix V Eight. The GB60’s are the superior driver here, but need a bit more power than I currently have available.
They’re listed as the same on their published specs, but the GS690 is actually closer to a 2-ohm driver. This was info from Andy the owner. I confirmed GS measure lower resistance on MM.I believe both drivers are 4 ohm
Wonder why he doesn’t change the marketing info then. That is good info to knowThey’re listed as the same on their published specs, but the GS690 is actually closer to a 2-ohm driver. This was info from Andy the owner. I confirmed GS measure lower resistance on MM.
when you say superior you mean in quality of sound or volume or both. what's the difference between a 6x9 and 6.5 in general?I’ve had both and am currently using the GS690’s. The GS690 has a lower impedance, so it gets more power from my current amp: Helix V Eight. The GB60’s are the superior driver here, but need a bit more power than I currently have available.
By superior I’m referring to the GB60 having lower distortion and what I perceive as better overall sound quality/tonality. I’m not saying the GS690 is a bad driver, it’s also really good. However, if I had more than 75W/channel available for them, I’d use the GB60’s. With all the performance aspects aside, the GS690 is significantly cheaper and like I already mentioned is a great performer.when you say superior you mean in quality of sound or volume or both. what's the difference between a 6x9 and 6.5 in general?
Thanks everyone I'm actually going with some HIFI Italia's BL4 3way set from ANS.By superior I’m referring to the GB60 having lower distortion and what I perceive as better overall sound quality/tonality. I’m not saying the GS690 is a bad driver, it’s also really good. However, if I had more than 75W/channel available for them, I’d use the GB60’s. With all the performance aspects aside, the GS690 is significantly cheaper and like I already mentioned is a great performer.
Your definitely going to love them, I really liked the bl4's when I heard them, very impressive. I absolutely love my Italia hifi stuff I've gotten from ANS.Thanks everyone I'm actually going with some HIFI Italia's BL4 3way set from ANS.
