1 - 13 of 13 Posts
· Registered
Stopping at HF the other day to pick up my usual free tarp, I came across this guy:
Priced at $7.99 I grabbed one using a 20% off coupon bringing the total to ~$6.40. Broken down to the square foot, it's ~$.53
Do you fellas think this will be adequate for decoupling my door panels from the frame?
I'll update this once it gets warmer and actually do the install.
· Registered
I went with waterproof house carpet padding instead.
http://www.diymobileaudio.com/forum...ound-reduction-journey-some-good-results.html
What I used was 8lb per square foot. What you have could be higher density. Just be sure that water will not be absorbed into that material if you get a leak. If you notice I put the waterproof membrane against the metal on my doors and club cab sides. I put the waterproof membrane on top under the carpet to keep the water from getting into the foam. That way I should never have wet foam against metal.
· Registered
Did any of you try it yet? 5/16" sounds way too thick since I'm having a helluva time fitting my door panels back on with 1/8" MLV + 1/8" CCF.
· Registered
Yeah I've got the plastic christmas trees and they just don't seem to be long enough. Or I need to trim more foam offa foam block. That's what it finally took on one side. DAY-UM no way they'd grab 7/16"! On other panels that used different fasteners I found longer ones at the auto parts store but haven't found taller trees.
· Registered
You cheated by avoiding all the christmas tree spots! I ended up cutting around them, dammit. and cutting more around them, dammit
1 - 13 of 13 Posts
