I'm replacing the Harman system in a '17 Outback and saw some interesting things. I don't Harman are idiots and would appreciate if anyone has any technical explanations.
1. Mid-range (500-8k?), just under right and left front windshield corners. Appears to be corner loading the driver, and they are seemingly trying to port the output directly up based on the plastic waveguide(?) mounted on the speaker (see pic). The grille has a short tube extending downward, to the plastic waveguide thing. The speaker grill only has holes in the middle of the tube (i.e., directly above the mid). Is this to manage early reflections?
2. The center mid has a soft dome and a complex plastic piece/guide on top (see other pic). This has the same grille setup (small tube, grille only perforated inside the tube). Again, seems like they are trying to ensure the majority of the sound goes straight up to the windshield and nullify off axis, non-reflected sound.
Thanks
Thanks
