hi , i bought a pair of L1v2 (thks doitor) and made a diy xover with a old pioneer xover that i have.
in complement with L1 i have a set of focal 165v2 ,the mid (6") has a 3500khz xover piont ,i can't use focal xover with L1, because the focal's tw are 8 ohms and a L1 are 4ohms, because of that i decided to build a diy xover for L1
i start with old pioneer xover that i have , this XO have a 2mf cap and 0,25mh coil
so i change the cap for 2 parallel caps (4,7 +3,3mf) for 8mf and the same coil to target 3500khz
upper xover is original pioneer and the lower y my modd
green is negative and red positive
L1v2 [email protected]/o , in manual Recommended Minimum Crossover
3,200 Hz at 24 dB/octave highpass
this is a good xover point for the L1 o maybe change the cut a little up, but with a hi cut the tw blend good with the 6"?
what do you think people?
thks Diyma see yaaaa
pd: go acitve is not an opcion
