1 - 9 of 9 Posts
Hi Guys,
I'm a little concerned about the spring loaded terminals on my HAT tweeters. Can I have full faith in these terminals holding the wires securely for a few years or is there a way to add something else? Am I over thinking this?
I'm not planning on pulling / tugging the speaker wires, but things happen. It's a car that's going to bounce around for 50,000 miles so I'd like to do this right the first time. I don't want to solder these on because the spring loaded terminal look to be chrome plated.
Any feedback is appreciated.
-Tom
if it is the same style terminals that subs use. I doubt they would come lose. subs create alot more vibration than tweeters and they dont come lose.
Pic attached of L1 Pro terminals (edit because of wrong image)
You're right. It's just a pain in the neck to get at these where they'll be mounted so I'm concerned.
They have a plastic cap that you can remove, and then hard wire to the back. I know a guy who did this and it worked very well.
if you strip the wire and push it in there, I bet you cant pull it back out withuot destroying the tweeter. those connectors hold pretty well.
I have that type of connector on my sub, solid for 2 years now.
My CDT ES mids use the same spring style. I slam the doors at least twice a day and play them loud. Been goin strong for 4 years now.
To answer your question, yes your over thinking it.
1 - 9 of 9 Posts
