Hello to All ,
Ok. Instead of changing the headunit, I have been thinking to place a HDD Media Player , then connect the player to Audison processor "Bitone" with optical cable and run stereo signals through the cable.
After all processor will deliver signals to analog amps which will run a 4 way active setup.
I will run wav or flac format files which will be ripped from my Audio CD collection.
The question:
How will be the signal quality which will run through the toslink cables. Can we talk abt any quality loss of signal as it will be delivered digitally to bitone. ( I will replace the fan of the HDD player with a heat sink to keep it in silence )
I am in between buying a real headunit ( i.e Clarion DRZ 9255 or P9 combo) and buying the bitone + HDD player + HDD
Note : Currently I have a 2 way + sub active setup connected to OEM unit with UCS Pro.
FYI:
The setup will have following other components:
Front Speakers: Audison TH 3 way active
Rear: Nothing
Sub: sealed box in the trunk 10" ( unfortunately there is no space for subw at the front) brand N/A at the moment.
Amps : 3 X DLS A3 to drive fronts and 1 X DLS A6 to drive the subw
Thank you
The question:
FYI:
Rear: Nothing
Thank you
