I'm using a Fiio x5 via optical directly to the Helix. Every time I turn the car off I have to go back in to the app settings and turn the digital volume up. Is there a way to get the digital volume to save at the desired db? I tried hitting refresh in the app settings but it still mutes the digital volume every time...
Are you using a Director? If so, on the Director go to Menu> Usability Settings>Startup Volume>Off. This will eliminate the auto mute of the optional inputs with each power cycle.
I’m guessing it’s a WiFi module... with a phone app
If so you need to go to the volume bit below the main and sub vol there’s a choice of startup volume for all sources, set all at off and it won’t adjust the volume on power cycling
Seems to be working now... seems like sometimes the wifi doeant save my settings even if I hit refresh
